Aluminum Upper Control Arms
Old Apr 26, 2017 | 05:27 PM
C3 Stroker's Avatar
C3 Stroker
Default Aluminum Upper Control Arms
Anyone using these?.....Speed Direct aluminum A-arms.....any concerns (strengthwise)? Upgrading some things (Borgeson box), and am consider these for some weight reduction.
Old Apr 26, 2017 | 05:57 PM
Big2Bird's Avatar
Big2Bird
I would ask them the material, temper, and if they are cast or forged.
I am curious, but will not compromise safety. The stamped steel ones are quite durable, and not that heavy.
Old Apr 26, 2017 | 06:44 PM
Dynra Rockets's Avatar
Dynra Rockets
The major advantage to these is not the weight savings but rather the additional caster you get from the slotted mounting holes
Old Apr 26, 2017 | 06:47 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I'll be honest, that big flat area with no reinforcement against flex/bend where the ball joint is mounted scares me a bit. I guess it might be fine with the correct materials, but I don't like the look of it. Compare it with the Global West arm, that has tubing tying that area from multiple directions, or the factory arms that are pressed with deep flanges around that area. Is there bracing underneath that's not visible in the picture?
Old Apr 26, 2017 | 08:17 PM
Dynra Rockets
A quick Google of their website says:
"Heat treated cast. Design strength safety factor of 5X - Stress / failure analysis results in 5X required load strength."
And here is a picture of the underside from the linked Super Chevy installation article
http://www.superchevy.com/how-to/vem...arms/#photo-12
Old Apr 26, 2017 | 08:36 PM
Big2Bird's Avatar
Big2Bird
The Global West arms are heavier. Stock arms would require phenomenal force to fail.
I would NOT use a cast piece in that position. On that I agree.
One of our Vette group is an engineer. That piece scares the hell out of him.
Old Apr 26, 2017 | 08:38 PM
Big2Bird's Avatar
Big2Bird
There are a few vendors out there with slotted shafts. Both steel and aluminum.
Old Apr 26, 2017 | 10:51 PM
Metalhead140
I'm an engineer also, though electrical, not mechanical or structural etc. But yeah, looking at it, I don't like it. That's not to say that they might not be ok - I'm not doing any modelling or anything - but I probably wouldn't run them on my car, and I'm a big fan both of extra caster and lighter weight.
There are plenty of OEM cast alloy suspension arms - done right it shouldn't be a problem. Here's the upper control arms from an rx7, but look at the difference in design.:
Old Apr 27, 2017 | 03:44 PM
C3 Stroker's Avatar
C3 Stroker
I see what everyone's saying about the possible weakness of the cast tab area.......I'm now leaning toward VBP's arms........similar weight savings and caster adjustment, but more strongly built tubular.....
Old Apr 27, 2017 | 09:23 PM
ddawson's Avatar
ddawson
Check but I recall issues with the aluminum VBP arms bending.
I went with the Steel Tube VBP arms
Old Apr 27, 2017 | 09:48 PM
zwede's Avatar
zwede
I've had these since they came out. 7-8 years or so?
Haven't had any problems with them.
Old Apr 27, 2017 | 10:02 PM
Richard454's Avatar
Richard454
I'm running and a fan of Vansteel's tubular A-arms.
They have been making for at least 12 years- haven't heard of any issues and that includes a LOT of track time.
This guy runs them- and if they could be broken- he's the guy that could do it...
and some others-
Old Apr 27, 2017 | 11:16 PM
Big2Bird's Avatar
Big2Bird
So are they any lighter than stock? Look kinda heavy.
Old Apr 28, 2017 | 12:25 AM
C3 Stroker's Avatar
C3 Stroker
The VBP's are steel tube, with aluminum cross shafts.
Old Apr 28, 2017 | 12:47 AM
C3 Stroker's Avatar
C3 Stroker
Are you referring to the VBP's, or Speed Direct's?
Old Apr 28, 2017 | 07:30 AM
jim2527's Avatar
jim2527
Compare them to a C4 and they look similar....
Old Apr 28, 2017 | 08:42 AM
zwede's Avatar
zwede
Speed direct.
To Aluminum Upper Control Arms
Old Apr 28, 2017 | 09:33 AM
Metalhead140
Your picture didn't work for me, but I googled to have a look. The c4 corvette upper arm looks more like the Speed Direct arm except in the very area I'm most concerned about. Around the ball joint the c4 arm maintains extra thickness and has nice tapers between the ball joint mount area and the arms. Compare that with the Speed Direct arm that has that big unbraced plate hanging out in space.
I dunno, obviously it works for some people. I feel sure it is an area of weakness, I guess it's more just a question of how likely it is to cause an issue in normal use, which I can't answer.
Old Apr 28, 2017 | 10:21 AM
zwede's Avatar
zwede
The upper arm has no twisting force, only push-pull.
I could understand your concern for a lower control arm, but not the upper.
Old Apr 28, 2017 | 10:34 AM
Big2Bird's Avatar
Big2Bird
I agree with that. The lower takes the weight, and the upper is just a guide per se. But I am leery of mods that compromise strength.
I have been in an old car that hit a curb going too fast around a corner. We almost flipped. (Kids then). All it did was bend an a arm. No cracks.
$25 for a new arm, and back on the road. It absorbed all the impact, and nothing else was damaged.
