Power window issue
Old Apr 29, 2017 | 02:37 PM
lsintampa's Avatar
lsintampa
Default Power window issue
1975 Coupe - right side power window
With the door open or shut - when I put the window up - it stops moving with about 1/2 of an inch yet to go - to where it would be completely up.
YET the window motor will still run and it sounds like it's run out of "teeth" or something.
I haven't taken it out - trying to avoid that if possible.
I'm thinking either something broke or is out of alignment.
Never been into this area yet - so it's a bit spooky.
Any ideas of what I'm going to run into?
Thanks,
Len
Old Apr 29, 2017 | 03:44 PM
oldboat's Avatar
oldboat
the teeth on the large gear(C) may have sheared off. the upper stops may be set too low.
the picture shows what is inside. somewhere on this site there is a better picture of the door innards shown from the outer side.
Old Apr 30, 2017 | 07:55 AM
fishslayer143's Avatar
fishslayer143
does it go up much much slower than it comes down? if so, its likely the return spring
Old Apr 30, 2017 | 08:18 AM
60 SHARK's Avatar
60 SHARK
Take a look here, it has great photos and info, I just freshened up one of mine, and this was the best info I found,,, may be others out there, It really is not hard, just take your time!
http://tech.corvettecentral.com/2011...glass-service/
Old Apr 30, 2017 | 09:17 AM
lsintampa's Avatar
lsintampa
Thanks for this. Hope I don't have to go that route. May get some time today to see.
Old Apr 30, 2017 | 10:44 AM
'75's Avatar
'75
You need a new regulator or a gear repair section, the top teeth are stripped off.
Old Apr 30, 2017 | 10:58 AM
drwet's Avatar
drwet
If you can hear the motor running and the window is not moving, the teeth are stripped off the gear.
Old Apr 30, 2017 | 11:35 AM
lsintampa's Avatar
lsintampa
yeah, pretty much confirmed that the teeth are worn off near the top end
ugh - not looking forward to this fix
thanks
Old May 1, 2017 | 09:26 AM
lsintampa's Avatar
lsintampa
Has anyone tried this repair?
http://www.parts123.com/corvettecent...50g&ukey=10163
I'll be pulling the old regulator out today... but assuming it is in "decent" shape, this part seems it will address the broken teeth issue.
Old May 1, 2017 | 09:42 AM
Bloodzone's Avatar
Bloodzone
It worked for me. My window was same as yours. Stopping short and still spinning. Works perfect now after fix. Takes a good afternoon
Old May 1, 2017 | 09:45 AM
'75's Avatar
'75
I put one of those on my drivers side thinking it was a temporary repair, that was 6 yrs ago, still working fine.
Old May 1, 2017 | 09:53 AM
60 SHARK's Avatar
60 SHARK
That repair piece looks like the best idea to me, shouldn't be too difficult, I'm guessing instructions would tell you which side of gear plate is best to install repair teeth, if your handy, I'm sure you could make your own repair piece too, , , really, it's 50yr old technology, pretty simple stuff, it will go well for you, enjoy the time tinkering on your car,,,,,,teddy
Old May 1, 2017 | 01:33 PM
lsintampa's Avatar
lsintampa
Torn between fix plate or replace the whole regulator.
Here's a picture of the regulator - including a close up of Grandma's teeth!
Makes me wonder what the left side looks like... I hate to think of it. This wasn't something that I had thought I'd be doing.
Only have had the car for a few weeks.... started out with replacing the AC with a Vintage Air unit (awaiting for it to ship).
The right door was messed up... couldn't lock it with the key, then if you happened to lock it - well that was that. Took out the latch - did some minor repairs there, now she locks and unlocks as she should.
Putting the window up and down while working on the stupid latch, well there ya go... Busted off some teeth on the regulator gear.
If the left side goes, at least I have a clue now what I need to do. There is so much more to do, that I'm taking the attitude that if the left blows, I'll deal with it then.
I think of it as character building.
Old May 1, 2017 | 01:43 PM
60 SHARK's Avatar
60 SHARK
Well isn't this why we buy C3 s , it's just great times workin on them, ,,,,ya could have bought a new one, but not as much fun and rewarding time togeather, what year is yours, those arms look like they have been exposed to a lot of harsh weather
Old May 1, 2017 | 01:57 PM
lsintampa's Avatar
lsintampa
1975 - coupe - 1980 Camaro Z28 motor.... a bit of a freak, but nice looking!
That's torch red BTW.
Old May 1, 2017 | 03:46 PM
'75's Avatar
'75
The right side is probably in much better shape, it doesn't get used nearly as much. You won't be sorry if you just replace the whole regulator, the rollers and the arm pivot are likely worn also.
Old May 1, 2017 | 03:56 PM
lsintampa's Avatar
lsintampa
I went with new regulator from Willcox - they had them on special so I went for the full regulator - as opposed to the dentures.
Thanks Willcox!!!
To Power window issue
