Always something
Old May 2, 2017 | 06:31 PM
croaker's Avatar
croaker
Default Always something
New issue. After changing out Strut Rods,spring bushing ,rear u joint and dif. bushing while backing off the ramp I had a popping ,roughness and a weird vibration that kinda went away. I thought maybe emergency brake stuck. The slight roughness and vibration hung on a bit and got a little better. So I'm thinking maybe that joint was a little tight. Anyway after about 30 minutes drive time I got on it a bit transmission seemed to start slipping bad in drive. I shifted to low was ok got home checked fluid was ok not burnt smelling. But it almost didn't make it up the ramps. The transmission guy said it could be the governor which I pulled and checked looked and moved alright. I keep wondering what I screwed up or is it coincidence the trans is going out. I done a little research and , only came up with Strut Rod binding. How would I check this ? Those bolts are pretty tight in the bushings.
Old May 3, 2017 | 07:42 AM
Alan 71's Avatar
Alan 71
Hi c,
How tight in the bushings are the strut rod bolts?
The strut rod needs to be able to twist a bit as it follows the arc of the trailing arm movement.
Regards,
Alan
Old May 3, 2017 | 11:20 AM
croaker's Avatar
croaker
Originally Posted by Alan 71
Hi c,
Regards,
Alan
I set them to torque specs I might put a wrench on shaft and see if they flex a bit
Old May 3, 2017 | 11:29 AM
croaker's Avatar
croaker
I feel like the bull in the China shop. Trying to go forward and keeping falling. This Forum is the only place I can gain any knowledge
Old May 3, 2017 | 11:15 PM
croaker's Avatar
croaker
Default Pics
Here's some pics
To Always something
