Engine misfiring sputtering on highway..
Old Jun 3, 2017 | 01:25 AM
  #41
corvetero's Avatar
corvetero
Originally Posted by zrc3john
Well here's the latest.....My mechanic changed out the fuel rod....When he told me it could be this I'm like " forgive me but I never heard of a fuel rod", fuel pump yes, fuel rod, no....
Basically the fuel pump has to be taken off to get to this....When I picked up the car he showed me a photograph of what looked like two pipes....One was smaller than the other....He explained the smaller one is the broken one that was in my car.....That was the problem I was told....
To be continued.....I guess the test will be a decent highway drive of some reasonable distance with traffic....
Then, how is that you had no spark previously? Weird...
Well, I hope that fixed your problem
Old Jun 3, 2017 | 11:50 AM
  #42
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
No spark? I remember the first time it did it a few seasons ago.....I was able to get it back to my garage.....Next day I go to start it, cranks but does not turn over..I tried it a few times, still no start..
A mechanic friend of mine came next day and pulled a distributor wire and determined, no spark.....Locked it up covered it and said- I'll mess with it later.....
Two days go by, I tried starting it and bamm, started right up.....
Yes, weird....
I'm hoping last repair is the last repair...
Old Jun 3, 2017 | 02:55 PM
  #43
Big2Bird's Avatar
Big2Bird
Old Jun 3, 2017 | 07:36 PM
  #44
sunflower 1972's Avatar
sunflower 1972
Originally Posted by Big2Bird
Yeah, good luck with THAT!
Old Jun 4, 2017 | 03:11 AM
  #45
Fredric Björnefält's Avatar
Fredric Björnefält
Could it be due to a boiling ignition coil ? Not unusual..
Old Jun 4, 2017 | 12:44 PM
  #46
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Well, did 110 miles yesterday.....55 each way back and forth from Brooklyn to Jersey........Hit a little traffic in Staten Island going.....
No issues with it yesterday....
Old Jun 4, 2017 | 01:02 PM
  #47
cv67's Avatar
cv67
St. Jude Donor '05
hope that fixed it, when you get time as one poster said get a new cap and rotor those are shot
Old Mar 24, 2019 | 04:28 PM
  #48
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Took me a while to find this thread....Took the car out today , first time in 4 months, stored it properly..
Well I'm on a street waiting for AAA same problem....Cars running great, starts to sputter a bit, idle drops than shuts off....
Let it sit for a while....Won't start just won't start....Cranks fine....Won't start...
Fuel sock, fuel pump, fuel rod, cap rotor, plugs all new..... Carb checked gas tank cleaned out....Same F in problem...
Old Mar 24, 2019 | 04:53 PM
  #49
4corvettes's Avatar
4corvettes
I think your problem is ignition related. I suspect your coil has been failing for some time and is just not ready to die yet. I would get a new one if it were me. Good luck!!
Old Mar 25, 2019 | 07:41 PM
  #50
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
with member "4corvettes"
Check the coil you may see it's bulging or leaking.
The scenario you describe is EXACTLY the same as what happened to me (although a '66).
Good luck- and let us know.
Old Mar 25, 2019 | 08:26 PM
  #51
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
I will let everyone know...My ignition is HEI....Motor is a 75 block....On your 66 I'm guessing it was easy to spot since the coil is right on top of the motor...
I just got it home and parked it....When I get a chance I have a spark tester and will see if I'm getting spark...
Payed for fuel pump, fuel sock, fuel rod and the problem still happens....Its dangerous as well....This S#%t happens at highway speed and everything shuts off .....
Old Mar 25, 2019 | 08:33 PM
  #52
Gunfighter13's Avatar
Gunfighter13
HEI/Spark Module sounds bad. Look at your MSD6L.
Old Mar 30, 2019 | 01:01 PM
  #53
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Ok so its a no spark condition...Put a tester on it and no spark....Having it towed to my mech.this week....3 tows in two weeks from AAA.....Glad I have the coverage..To be continued ..
