Engine misfiring sputtering on highway..
Old May 7, 2017 | 04:50 PM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Default Engine misfiring sputtering on highway..
Reason I say the highway is because a few years ago I'm on the highway and car begins sputtering than backfiring....I pull over,car sounds like it's running on six cylinders......I thought bad gas, because everything looked fine......I let it cool down.....Not that it was running hot.....Car was fine, got it home .....
Next day I tried starting it, no start but cranks....I had no spark...Two days later car starts......???? Took it to my mechanic couldn't find anything wrong....
Next month on highway, same thing sputtering backfiring....Pulled over, let it sit for awhile, started, got it home.....
Last season didn't do it....Car ran fine..Put about 700 miles on it last season..
Today on highway and guess what? Started again.....Pulled off nearest exit and called AAA.........Towed to my house where the car started and I put it in garage...
Car is a worked small block four speed .....I'm thinking it may be a spark problem? Car has MSD 6 AL.....The times I bought it to my mechanic he says it's hard to diagnose because it's not doing it when I bring it to him..
Any idea what could be causing this......It's not something that happens all the time and car is well taken care of.....
Car is a 1973 ....
Old May 7, 2017 | 09:18 PM
sparky77's Avatar
sparky77
Sounds like it could be a fuel filter or something in the tank that when in the right position blocks the fuel inlet.Or a wire rubbed bare and touches to ground.
Old May 7, 2017 | 09:48 PM
Big2Bird's Avatar
Big2Bird
Car is a 1973 ....
Sounds like the filter sock. Ever change it? They collapse when old at high speed, and shut the fuel off.
Old May 7, 2017 | 09:52 PM
diehrd's Avatar
diehrd
Of course fuel filter , but you can not rule out ignition which will behave badly such as you describe.
If you had a GM HEI in there you would be getting told the Ecm is bad because they would do just as you describe sometimes when they started to fail
Old May 7, 2017 | 11:46 PM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Yes I have HEI....Its not the original motor..
Old May 7, 2017 | 11:48 PM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Filter sock? Never heard of that before ...The fuel filter is right in front of the carb..Is the filter sock possibly in gas tank?
Old May 8, 2017 | 12:21 AM
BLUE1972's Avatar
BLUE1972
Filter sock is in the tank on the end of the pickup.
When the car reacts to heat, normally I look at the Heli electronics or the coil is bad.
An oddball I had was a fuel line too close to header pipe causing a boiling situation in the fuel line.
Hope you find it.
Old May 8, 2017 | 07:05 AM
terrys6t8roadster's Avatar
terrys6t8roadster
You mentioned MSD, what coil are you using, I've had numerous MSD coil failures cue to coil overheating and leaking oil. I now use the ceramic coil. As coils heat up when failing the problem you described, well maybe a new coil is your cure. To bad there aren't any Sun 1020 scopes around any more. T
Old May 8, 2017 | 07:14 AM
Big2Bird's Avatar
Big2Bird
I have one, and two dizzy sun machines.
Old May 8, 2017 | 07:16 AM
Big2Bird's Avatar
Big2Bird
Yes, in the tank. After 40 years they die.
Old May 8, 2017 | 08:05 AM
terrys6t8roadster
Ya, but you are to faaaar away. Sure do miss them for diagnostic work. T
Old May 8, 2017 | 08:07 AM
jersey68l36's Avatar
jersey68l36
Suggest concentrating on whether there's a problem with the ignition box. If it will start/run okay at cold start, shut it off, and leave a trouble light with an incandescent light bulb, you know the old style bulbs that heat-up on top of the MSD control box, in an effort to simulate normal under hood heat. Once the box is really warmed up, (hot to touch) try starting it up. No-start=bad ignition box.
Old May 8, 2017 | 10:22 AM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Not too sure what coil is in there....The weird thing about this problem is that it happens after long trips ( 40-50 miles)...I was on the last leg of a 55 mile trip yesterday when it started happening...
Old May 8, 2017 | 10:27 AM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Thanks for all the replies....Spoke to my mechanic about it this morning...At times over the years my fuel pressure gauge sometimes would read 2-3 psi...This was a concern but the car always always ran great...Only issue was what I posted...He feels it could be a fuel issue, will see...
I'm going to change the fuel sock anyway....I'm not running the tire carrier and the spare so taking the tank down will be easier....
Old May 8, 2017 | 10:41 AM
Big2Bird's Avatar
Big2Bird
Even if that's not the issue, it's done, and needs a new one anyhow.
Old May 10, 2017 | 06:17 AM
gguillot's Avatar
gguillot
Before you tackle the sock in the tank, did you check the fuel filter in the carburetor or inline to the carb? My '73 had very similar symptoms and it was the fuel filter in the Quadrajet.
Old May 10, 2017 | 09:49 AM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
I have a Holley 750 CFM on it, it's not the stock carb....Fuel filter is on the fuel line in front of carb....It was changed two years ago...Should get it into the shop at end of week .....Will keep everyone posted in case they run into a similar problem..
To Engine misfiring sputtering on highway..
Old May 13, 2017 | 09:42 AM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Well my mechanic changed the fuel sock..He explained to me that it was totally clogged up basically.......Could this be the problem? Let's hope...In his words he was like ,it was something he did not like....Fuel pressure was checked and everything seems good...
May take a 150 mile trip this week so I'm keeping my fingers crossed...
Old May 13, 2017 | 09:56 AM
Big2Bird's Avatar
Big2Bird
Absolutely that will cause that issue. I have seen it quite a few times in the last few years.
Old May 14, 2017 | 09:22 PM
maj75's Avatar
maj75
How is the sock changed?
