From: Slower than a speeding bullet................ Fort Lauderdale, FL
Removing power window switch on console - 1971
Some genius installed the p/w switches upside down, so to make windows go down you press what would normally be up.
I tried prying out the switches to turn them around but couldn't remove them. Are they supposed to be removed with the console removed, or can they be removed with console in place?
Thank you.
Just remember.... there is a hidden bolt for the parking brake console in the rear storage compartment. You'll need to access it before you can remove the console.
