What did I just fry?
Old May 17, 2017 | 04:45 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
Default What did I just fry?
Good grief. Chasing down my ignition problem which I'm pretty sure is a plug boot arcing to the header. It's melting the boot.
But, I have my timing light hooked to the alternator with alligator clips.
Nothing is running, the key is not even turned on, I'm messing with the plug wire and all of a sudden I hear crackles and smoke's coming from the positive alternator terminal. The clip was trying to weld itself to the terminal.
Now everything's dead as 4 o'clock.
WTH?
Good thing I don't do this for a living
Where should I start looking?
Old May 17, 2017 | 04:52 PM
TimAT's Avatar
TimAT
Start at the beginning. That big red wire on the back of the alternator runs from there to the starter with a couple of fusible links in-line. Track it down with your 12v testlight. No real cause for alarm, the links probably did their job.
Old May 17, 2017 | 04:53 PM
blue by you's Avatar
blue by you
check the fuseable links
Old May 17, 2017 | 06:20 PM
Capt. Shark
I thought maybe fusible link. Now I can't find my test light.
Marvelous.
Old May 17, 2017 | 06:33 PM
theandies's Avatar
theandies
Marvelous.
Welcome to my world.
Old May 17, 2017 | 06:36 PM
Capt. Shark
Ain't it great?
Old May 17, 2017 | 06:42 PM
DUB's Avatar
DUB
Knowing what year model would be great due to the fusible links changed locations. But I agree that a fusible link more than likely burnt.
DUB
Old May 18, 2017 | 07:15 AM
Capt. Shark
DUB
It's a 79. When I couldn't fine my light, I quit. I'll dig out my wiring diagrams and start looking for them. Another thread mentioned just upstream of the starter?
Old May 18, 2017 | 05:10 PM
Capt. Shark
It lives Fusible link at the starter. Still don't know why just having my timing light connected to the alternator terminal would fry it, though.
Thanks guys
Old May 18, 2017 | 05:19 PM
TimAT's Avatar
TimAT
That big red wire runs from the alternator down to the starter. May make a couple of stops between, but in basic terms, there you go.
Old May 18, 2017 | 05:57 PM
diehrd's Avatar
diehrd
BIG RED WIRE GOES TO BATTERY .... Big RED FROM battery goes to STARTER
Old May 18, 2017 | 07:01 PM
DUB's Avatar
DUB
I am NOT saying that you did not fry a fusible link....but what is oftentimes overlooked is this connector that comes up from the starter that GM started using for faster assembly times...because it DOES NOT make the car better. Just one more point of failure
I have seen these get rather 'touchy' and in a situation like what happened to you can cause this connector to have an attitude and sometimes pulling it apart and inspecting/cleaning it and putting it back together helps due to the years of dirt and high amp current load that goes thought this connector.
DUB
Old May 19, 2017 | 04:10 PM
theandies's Avatar
theandies
Ain't it great?
I'm starting to lose tools that I just put down after using them.........It really sucks getting old.
Old May 19, 2017 | 04:21 PM
TimAT's Avatar
TimAT
DUB
Starter extension Harness. Whatever bonehead engineer dreamed up that should have his/her pencils all broken.
Old May 19, 2017 | 05:39 PM
DUB's Avatar
DUB
DEFINITELY one of the most bone headed ideas. It may be great for speed in assembly...but long term...it is a joke.
DUB
Old May 19, 2017 | 08:08 PM
sunflower 1972's Avatar
sunflower 1972
Thanks, it's nice to know I'm not the only one that has that problem.
Old May 19, 2017 | 09:15 PM
Capt. Shark
I feel your pain, my brothers. I'll swear I can have a wrench in my hand and 10 seconds later it's like the sumbitch never existed
Old May 19, 2017 | 09:18 PM
Capt. Shark
DUB
Thanks for the heads up, I'll have a look
To What did I just fry?
