Steering Column Mounting Question.
Old 05-21-2017, 07:46 PM
Cavu2u
Cavu2u's Avatar
Default Steering Column Mounting Question.
This Column never had them installed when I got it, so I'm assuming these collapsible Mounting Blocks push into the column's Mounting Plate this way.
Is this correct?
Thanks much.
Steve
Old 05-22-2017, 07:00 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Steve,
Looks to me like yes.
It there an upside/downside to the blocks or are they symmetrical?
Regards,
Alan
Cavu2u (05-22-2017)
Old 05-22-2017, 07:36 AM
Cavu2u
Cavu2u's Avatar
Good Morning Alan,
Thanks for the response.
Only difference between the part's "top" and "bottom" sides are 2 holes on one and a part stamp on the other. No height or protrusion differences observed.
Also noted is one square corner on the part's oblong hole.
Interesting.
Steve
Old 05-22-2017, 08:41 AM
Alan 71
Alan 71's Avatar
Hi Steve,
This is from my 71.
Regards,
Alan
Cavu2u (05-22-2017)
Old 05-22-2017, 11:46 AM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
At the Saginaw manufacturing plant, the two mounting blocks, (we called them capsules), were installed on the column bracket and then hot molten plastic was injected into the two holes in the capsules. This locked the capsules in place and kept the mounting tight and secure. Yet, the plastic could shear and the capsules could easily allow the column to compress into the dash structure in a severe frontal collision. You might consider using small amounts of epoxy glue to hold the capsules on the column bracket. Epoxy glue is actually just a gap filler and should work acceptably.
Jim
Cavu2u (05-22-2017)
Old 05-22-2017, 01:44 PM
Cavu2u
Cavu2u's Avatar
Originally Posted by Alan 71
Hi Steve,
This is from my 71.
Regards,
Alan
Thank you for the detailed photos Alan. You had to have removed a shield and the ducting to expose it all.
Steve
Old 05-22-2017, 01:49 PM
Cavu2u
Cavu2u's Avatar
Jim
See?
I mentioned it was interesting!
Many Thanks to you Jim for that little bit of historical engineering.
Steve
Old 05-22-2017, 02:11 PM
Alan 71
Alan 71's Avatar
Hi Steve,
I was curious too!
Just 3 screws and there it was… no a/c duct!
Regards,
Alan
Cavu2u (06-08-2017)
To Steering Column Mounting Question.
Quick Reply: Steering Column Mounting Question.
