If You are Having Difficulty Removing or Installing Radiator....
I have a '73 with AC, so with the condenser bolted to the front of the radiator support, you can't pull far enough forward on the support to get the lower radiator pipe clear of the control arm and the fan shroud.
It took me all of 30 minutes to disconnect both actuators and then another 5 minutes to set the radiator and shroud back in the car - without a second set of hands.
It was this post by redwingvette back in 2002 that made me realize the actuators had to come out:
https://www.corvetteforum.com/forums...ve-a-arms.html
Default Re: Fan Shroud Again - Remove A-arms? (theandies)
I've done mine aleast 4 times so I'am getting good at it.
1. Remove core support bolts inside wheel well
2. Remove fan
3. Remove fan shroud bolts, radiator and condenser bolts (remove hoses and trans lines if you plan on pulling radiator).
4. Remove headlamp actuators (gives room to pull radaitor support toward front of car.
5. Pull radiator as far forward as you can and wiggle fan shroud pulling up the driverside first.
6. Reverse to reinstall.
Here's a link to a great thread on removing the actuators :
https://www.corvetteforum.com/forums...-actuator.html
In this pic, you can see that I have another 3-4" of clearance to pull the radiator support forward now that the actuators are out.
And yes - good time to refurb those actuators!
Definitely appreciate this tip.
Adam
I am about to do this so will be following the thread, I have watched videos but it was on cars without AC and mine has AC.
On my '73, I could do this without loosening or removing the condenser or the hoses, although you may need to remove any brackets holding the hoses to the engine compartment in order to let them move forward.
Once the support is loose (and assuming the radiator has been complete disconnected) push it forward and then pull the shroud back and see if you have enough room to pull out the radiator - the problem with doing it with the shroud is clearing the shroud over the control arms.
If you don't have enough room (I didn't.) Then remove the actuators and push the support forward another 2-3 inches and then you should have plenty room to pull the radiator up and out, while clearing the lower pipe.
I did this with the hood off, don't think it could be done with the hood on.
Again, this is all my experience. Others seem to have an easier time with it - but I'm thinking it may be non AC cars or different shroud setups.
Also - remove the front section from the shroud first too.
