Flywheel ring gear.
Old May 26, 2017 | 01:38 PM
Zoix's Avatar
Zoix
Default Flywheel ring gear.
I've been doing some clutch/fork/ball stud/pilot bearing work on the hot rod and noticed my flywheel ring gear has a few nicked teeth. What if I just flip the ring gear on the flywheel, the teeth are in virgin shape from that side. Has any of the brethren done it. Should I opt for a new gear?Thoughts comments? A new SFI approved flywheel looks to be in the $230.00 range. Engine sees 6000 rpms occasionally.
Old May 26, 2017 | 02:19 PM
JoeMinnesota's Avatar
JoeMinnesota
If it isn't giving you issues (grinding starter drive?) I wouldn't mess with it - if a few have some jags, file the rough spots out of the teeth. The ring gear can be replaced by a shop that does engine/flywheel work if you want the same flywheel.
You can also find a steel flywheel at Summit for around $100: https://www.summitracing.com/parts/pio-fw100
I wouldn't waste the money on SFI unless you are racing it and winding it constantly MHO. Steel would be safer than the stock cast flywheel in any case. In my case on a fresh rebuild, I opted for the Summit part and my old one is "stored" now.
Old May 26, 2017 | 03:08 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
yes, you can flip the ring gear.
Old May 26, 2017 | 07:34 PM
Zoix's Avatar
Zoix
Thanks for the feedback.
Old May 26, 2017 | 09:26 PM
68notray's Avatar
68notray
Yep - flip it over. You'll have to heat it and it'll fall off. Quickly flip it and reinstall before it cools.
To Flywheel ring gear.
