inside the so-called "proportioning valve"
I pulled the bracket off the back, just in case there was some access covered up there, but there is not.
From the front, the electrical switch pulls out pretty easily. It slides in an insulated shaft and presents some 10 megohms of resistance to the insert, so pretty much an open circuit to the light bulb on the dash.
Inside, installed somehow is a shaft that I assume slides back and forth to make electrical contact with the little piston on the electrical post. You can just see it in the picture.
If I blow compressed air into either supply side, the air only comes out the ports connected to that side of the MC. So brake pressure is probably pretty well isolated front and back at least at the low pressure I can supply. I presume the way this works is as has been described by others, a little slider that makes contact with the plunger and supplies a ground if it moves off center. I can't make it move with a pair of tweezers so the tolerances are pretty tight in there.
Now, hydraulics 101. Pressure is measured in pounds-per-square-inch and area is of course square-inches. In a hydraulic system pressure travels at the speed of sound in the fluid, and is the same everywhere once equilibrium is reached. Orifice sizes do not matter at equilibrium. So the force exerted at the caliper pistons is simply psi X area, i.e. pounds of force. Simple enough units. The area of the rear pistons is a fraction of the front pistons and that is how brake bias is built into the system. Absolutely straightforward engineering.
Furthermore I have measured the hydraulic pressure in my system and it is the same front-to-back. The proportioning is 1:1. Even the time to reach full pressure from videos I took is the same front and back, indicating there are no other dynamics at work.
Here are the parts in the distribution block. I challenge someone to show me where the "proportioning" takes place. There is none!
This may not be evident by pedal feel as the healthy side will retain its normal pressure against the pedal and your foot.
There will be some design incorporated into the switch piston and how it interacts or valves between the two sides that allows it reset to centre once the side that went low pressure has been repaired. Because the reset instructions are to "stamp the pedal" or "push the pedal swiftly" or some similar description.
Proportioning, as you explained is built in to the system by piston size between front and rear calipers.
Appreciate the authentication of the part. There's a #223 in crayon on the rear of the passenger compartment wall. Sounds about right, mine was built in late 68 sometime. Thanks 62
