Ka BooooM
Old Jun 9, 2017 | 03:21 PM
patrick68's Avatar
patrick68
Default Ka BooooM
Well I got ambitious 2 months ago and decided to install all of the ignition heat shields on my '68 small block.That project was short lived as i discovered i didn't have all of the correct pieces. Ok, on to project number two. A tune up. You know the the easy stuff, points plugs, wires, rotor cap.
This is were everything goes sideways. The car started and ran fine before project #2
I install everything( know I have been working on engines of all types most of my life ).I start it but it's popping through the carb and exhaust and idling very fast, never touched the carburetor. Everyone tells me "crossed wires". I checked them and the firing order so many times I lost count. I put the old cap and rotor back in, check the order again. Result, same. I pull the left valve cover to verify TDC on #1 cylinder comp stroke. Static time it with the rotor facing towards the #1 cylinder , #1 plug wire to #1 on the cap from #1 plug. I try to start it and .......Ka Fricking Boooom. My ears are ringing and there is a hole in the left muffler. firing order"18436572".
Any Thoughts?
Old Jun 9, 2017 | 03:29 PM
dochorsepower's Avatar
dochorsepower
Might be timing chain slipped a tooth or two.
Old Jun 9, 2017 | 03:56 PM
ted13b's Avatar
ted13b
Did you pull the distributor for anything? It could be 180 degrees out.
Old Jun 9, 2017 | 04:03 PM
blue by you's Avatar
blue by you
crossed wires
Old Jun 9, 2017 | 04:38 PM
patrick68's Avatar
patrick68
I thought about that, but the engine only has 52,000 easy miles on it.
it is possible though. Thanks
I did have the distributor out to check the pin. When I am on the comp. stroke TDC both valves closed. the mark on the crank dampener is lined up with the "0" on the timing cover and the rotor points towards #1 cyl.
Old Jun 9, 2017 | 04:43 PM
patrick68's Avatar
patrick68
Originally Posted by blue by you
crossed wires
Hey I like that user name. Thanks for the response. I lost count of how many times i have checked the wires. maybe if I try one mo time. Thanks.
Old Jun 9, 2017 | 07:44 PM
blue427's Avatar
blue427
you have the timing set up on 0 before top dead center,advance it to about 8 degrees before top dead center then it'll start.play with it after that. Read Lars papers on timing.
Old Jun 9, 2017 | 08:48 PM
gkull's Avatar
gkull
This is just a wag, but your motor is firing with valves open. The stock damper are prone to breaking between the inner and outer ring. It causes the timing mark to slip
Grab the outer ring and tq on it. Your cure is to probably get a damper puller/installer and a new damper
Old Jun 9, 2017 | 10:45 PM
stumpshot's Avatar
stumpshot
Sounds like you are out of time to me. Advance the dist until it starts.
Old Jun 10, 2017 | 03:59 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Are you referring to 'rotor point to #1 cyl ' or #1 plug wire on cap? On a 68 SBC with OEM style tach drive distributor with #1 at TDC of compression stroke the rotor should be pointing towards the 5th from the front intake manifold passenger side bolt hole. Make sure the distributor is in correctly. Then orientate the wires accordingly. Refer to any manual.
If you were attempting to use OEM radio shielding you are running the front plug wires between the block and motor mount, very easy to get the wires crossed. Use a ohm meter to make sure they are correct. T
Old Jun 10, 2017 | 07:53 AM
Tiger Joe's Avatar
Tiger Joe
Out of time.
Old Jun 10, 2017 | 12:21 PM
gerry72's Avatar
gerry72
By what method did you set the points?
Old Jun 10, 2017 | 02:16 PM
SH-60B's Avatar
SH-60B
I agree with Tiger joe. You had the dizzy out, you are simply out of time.
Old Jun 10, 2017 | 08:08 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Never trust old Rubber mounted Timing mark,
Degree the wheel for true 0 degree #1.
you will chase your but when 1 has slipped, and they do move.
Old Jun 11, 2017 | 01:07 PM
7T1vette's Avatar
7T1vette
When the plug wires are run through that shielding, it is difficult to know which wire is which. You need to use an ohmmeter to verify each individual wire; tag them with the associated plug number ON BOTH ENDS after you verify each wire. THEN hook them up as intended.
{You DO have the sequence of wire going the correct direction on the distributor, don't you?}
Old Jun 12, 2017 | 03:17 PM
Kacyc3's Avatar
Kacyc3
check the basics, you said you checked the order, and the wires but any chance you numbered them like ford does?
DS PS
1 5
2 6
3 7
4 8
Old Jun 12, 2017 | 04:53 PM
gerry72's Avatar
gerry72
Actually, Ford's #1 is the front passenger side, not DS.
Old Jun 12, 2017 | 09:52 PM
Kacyc3's Avatar
Kacyc3
that was off memory, I timed one 10 yrs ago
Old Jun 12, 2017 | 10:51 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
5&7 crossed. Ask me how I know.
To Ka BooooM
