Ambient R12 Chart
Old Jun 10, 2017 | 05:14 PM
Vettesic's Avatar
Vettesic
Default Ambient R12 Chart
I need an ambient temp chart for charging R12 ac system. Needs to have factory specs for high/low pressures on a system for a 71. I know 134 charts are on net but is R12 the same readings? A pic or linc will do. Thanks.
Old Jun 10, 2017 | 05:48 PM
gerry72's Avatar
gerry72
Temperature/pressure charts are online for all refrigerants. The high and low specs will depend upon the temperature and humidity (as well as air flow through the condenser). This is where the gauge set comes in. Though you could just evacuate the system and charge it by refrigerant weight, which would be ideal.
Old Jun 10, 2017 | 08:04 PM
Vettesic's Avatar
Vettesic
System is already evacuated. In process of vacuum down and check for leaks. If I charge by poundage I don't need to check pressures?
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
See if this helps.............
https://www.corvetteforum.com/forums...-how-much.html
Old Jun 10, 2017 | 08:39 PM
Vettesic's Avatar
Vettesic
Originally Posted by KapsSA
yes. Thanks.
To Ambient R12 Chart
