Power Sterring problem
Old Jun 10, 2017 | 07:32 PM
cruisergg's Avatar
cruisergg
2nd Gear
Default Power Sterring problem
I just replaced all of the hoses, and when I refilled the pump and started the engine, the wheel went crazy, I cant move the wheel at all, what should I have done? what can I do now ? it did work fine before this but the hoses had a lot of cracks,
Old Jun 10, 2017 | 07:38 PM
terry82's Avatar
terry82
http://repairs.willcoxcorvette.com/w...adjustment.pdf I think you need to get all the air out first .then do this procedure
Old Jun 10, 2017 | 07:49 PM
'75's Avatar
'75
Make sure the hoses are crossed where they exit the control valve or bad things will happen.
Old Jun 10, 2017 | 09:01 PM
V4motorsports's Avatar
V4motorsports
This might help you.
Russ
Old Jun 11, 2017 | 01:02 PM
7T1vette's Avatar
7T1vette
You should have rid the P/S system of MOST of the trapped air by exercising the wheels with engine OFF (right/left several times with wheels off the ground). THEN you do the same with engine ON. And then you center the control valve adjustment so the wheels do not drift either direction on their own. Hopefully, you have not damaged the seals in the control valve during that "seizure" episode.
To Power Sterring problem
