Finally !
Old Jun 15, 2017 | 10:17 AM
upnorth's Avatar
upnorth
Default Finally !
1976 /350 .The maybe will maybe not project . Just picked up my car after finding a new guy that was suppose to work well with older engines . For 30 years I have been trying to get my car to spin the tires without bringing it up to 2500/3000 with my foot on the brake . Had a Rpm Air Gap ( had torker 2 ) installed and tuned . It fit fine under the hood no problems at all . Now the car at idle if you stomp on it smokes the tires also the acceleration will push you back in the seat . It ended up at 34 degrees advanced , at 35 he said it started to ping a little with 91 oct gas . He said with a higher octane gas there is still more in the engine . So I really don't know if its the intake or the guy's tuning that made the improvement . I'm going with 40 pct intake 60 pct tuner . Also for the first time in years I can put the car in park and when I turn the key it shuts right down .
Old Jun 15, 2017 | 12:36 PM
ddawson's Avatar
ddawson
It's great when they run right.
Old Jun 17, 2017 | 09:19 AM
upnorth's Avatar
upnorth
Took it on another 70 mile ride . No change running fine hard part now is keeping it under 60 ( speed limit around here 55 until you get 80 miles from here ).Did it yesterday but it was hard not jumping on it since most of the time I drive in the country , closest town is 15 miles away .
Old Jun 17, 2017 | 11:16 AM
REELAV8R's Avatar
REELAV8R
Speaking of steering a guy in a direction, Here is your next mod if you want to get back some HP and TQ.
Old Jun 17, 2017 | 05:30 PM
upnorth's Avatar
upnorth
Put a aluminum fan on 25 years ago with not much bend in the blades .
Old Jun 17, 2017 | 08:27 PM
REELAV8R's Avatar
REELAV8R
Did you watch the video? You could be giving up 30 HP at 4800 RPM or there abouts with that design. Just sayin that's all.
Old Jun 18, 2017 | 09:14 AM
upnorth's Avatar
upnorth
According to that I should be somewhere under 20 hp lose . My fan looks a little less aggressive then the one they have and if I remember right its a flex type . I would like to put mine on a dyno but other then a stand dyno the only chassis dyno I know of is over 200 miles away , and if I were to break something that could be a problem .
Old Jun 18, 2017 | 11:48 AM
caskiguy's Avatar
caskiguy
https://www.youtube.com/watch?v=ZXdLgaFXZzs
Just what I needed to see.
Old Aug 9, 2017 | 09:30 AM
upnorth's Avatar
upnorth
Decided yesterday to push it a little .Haven't really pushed it off the line since i got it back . For a car that i couldn't get the tires to break free at all unless i brake torqued it to around 3000 and then i only got about one tire rotation . I took it up to 1400 and it smoked them for 30 feet + .For being a kind of hodge podge build because i don't know what cam i have and there's been 20 years since i built it and what i have had done now , i am pretty satisfied with the results .Seems like i have a good combo now but i really don't know what it is . Unless something breaks everything i have to do now is cosmetic .
Old Aug 9, 2017 | 07:49 PM
sunflower 1972's Avatar
sunflower 1972
Was it dyno tuned or static tuned?
Old Aug 10, 2017 | 09:25 AM
upnorth's Avatar
upnorth
It was tune at a persons house that works at a auto dealer that has a garage set up that does a lot of the local work and also some of the dirt track cars . I went back to where i burn the tires it wasn't 30 feet actually a little over 20 .
Old Aug 10, 2017 | 03:47 PM
Richard Daugird's Avatar
Richard Daugird
Not to be a smart *** but poor traction isn't really a measure of performance. Just sayin'.
Old Aug 10, 2017 | 05:38 PM
upnorth's Avatar
upnorth
So why would you assume there was bad traction . When I compare things its pretty much apples to apples . Its on a couple year old blacktop and before I had the work done it would hardly squeak them . Plus I am the only one that drives the car and as long as it impresses me that's all that counts .
Old Aug 10, 2017 | 06:21 PM
VERYSOON's Avatar
VERYSOON
Smoke 'em if you got 'em!!
Old Aug 10, 2017 | 08:37 PM
upnorth's Avatar
upnorth
I look at it this way . With the type insurance I have I can only put 3000 miles a year on . So new tires would get somewhere between 10 and 15 years on them by mileage . Last set I had the thread looked like new when I change them but they were over 10 years old .
Old Aug 10, 2017 | 11:42 PM
cagotzmann's Avatar
cagotzmann
I would be interested in your Top MPH at a 1/4 mile track.
That would be a good real world performance report and fun at the same time.
Old Aug 11, 2017 | 08:43 AM
BEJ's Avatar
BEJ
Great. Just when I thought that I had settled on sticking with the stock fan setup, you go and post this.
To Finally !
Old Aug 11, 2017 | 09:53 AM
upnorth's Avatar
upnorth
Don't have anything close , dyno or 1/4 mile . There is a dyno around 60 miles from here but its not a chassis dyno . Closest is over 200 miles and i don't want to have to pay 1000 bucks to get me and the car back if i broke something . But back in the 90's i did have it on Bristol Race Track for a lap .
Old Aug 11, 2017 | 10:38 AM
REELAV8R's Avatar
REELAV8R
It's funny 5 years ago I couldn't hardly convince anyone that the stock cooling fan is a HP sucking device compared to electric fans. Now there is a video and dyno evidence that people can watch and that makes it more believable somehow. Dyno's had been done before this video proving how much HP a mechanical fan consumes yet it was contested heavily.
Even if it's only 20 HP, that is 10% or more of the HP a stock, mid 70's till the end of the C3 run, corvette develops. That is only one advantage of the electric fans.
When I switched to electric fans I could feel the difference in acceleration.
Now back to the subject at hand.
Old Aug 11, 2017 | 12:00 PM
caskiguy's Avatar
caskiguy
I watched the same video, impressive. There are many newer advancements that can be applied to a older Corvette to make it a better machine, question is do the people who own these cars have the time, knowledge, desire and money to apply them ? But there are those myself included as I rebuilding my 1970 that waffle at the thought of having something close to original or actually all original. Will it matter to the next owner ? But I'm not building it for someone else, I'm building it for me. But of course I'll still waffle.
