Wipers, one last try:
Now on the bench... do the following:
Connect the wire as shown in A.
Connect ground wires to C E and F
Connect power to D
Then connect power to B.
The motor should run in low speed. If it doesn't then the issue is the wiper motor.
If it does, then the issue is in the car.
Willcox
Connect power to D
Willcox
I had a friend over tonight to play with the motor, since he likes stuff like this and it was a good excuse to drink beer. I would call the testing session a partial success. When we followed the directions above, the motor did, in fact, run at low speed. So, that was a success.
Then, we referenced the general bench test instructions from the Willcox site, and played with high speed and parking. We got it to run on high speed a few times, and to park a few times, but parking was unquestionably unreliable. We did something that caused some smoke to come out of the motor once, but could not re-create it, etc. When it would not park, we would shut off the motor, and I would rotate the plastic wheel on the parking switch by hand, and then it would park once or twice, before not parking again.
At the end of our play session, we decided that the motor was, in fact, "working", but not exactly what I want in my car when I am hundreds of miles from home. So, I want to get a rebuilt one (will order it tomorrow), but I think we need to assume there is some problem in the car.
Please let me know if you have any guidance on where to go from here.
Thanks!
PK
But if the motor isn't parking, you have two choices.. find a park switch or buy a new motor. Personally, I'd buy the new motor without a core. The only thing I'm worried about the new motor is they were on backorder and I can't get an answer on the stock status of them right now. I've posted both links below though. I know I have the rebuilt in stock.
Now that you know the motor is in working condition though you could use the car wiring on it and see if it works off the car. If you are replacing the motor, then don't mount it... just hook up the wires and hold it in your hand... it should respond the same as the bench test.
https://willcoxcorvette.com/corvette...-rebuilt-69-72 Rebuilt w/core
https://willcoxcorvette.com/wiper-mo...-no-core-26559 New, No Core.
Willcox
Connect power to D
Willcox
Before undoing the bench test connectors, I disconnected the connection at A in the above picture. I then tested the end closer to the wiper motor body (the side without the red splice on it. It showed no volts, and full continuity to ground.
I then connected the motor to the car's wires, and that same wire showed 12.7 volts, and no continuity to ground. Any ideas what has gone wrong here?
A long session of looking at the wiring diagram with a magnifying glass (I'm not getting any younger), lead me to look at the wires in the car again. I want to look at it again tomorrow when I have not had this level of beer, but I got ground where I wanted it. I'm sure I will have more questions going forward, but I am guessing I'll get the wiper motor running in the car.
I'm in Maine for three weeks but I'll keep checking back..
BUT, putting it back in the car, I still had the short-circuit problem that I did NOT have on the bench. So something has to be screwy with the wiring in the car.
At the end of last night, I seemed to have gotten rid of the short circuit, and everything tested in the car like it did on the bench. I want to go over it again before I connect to full power; I could do that tonight, but my son will be home tomorrow, and he is better at electrical things than I am. I think now is a good time to have him look everything over before running full battery juice through a system that recently had a known short.
Thanks for all the help to date! Have fun in Maine! Hopefully I'll be out driving the car by the time you get back to the office!
New pic:
I'm pretty sure this is the way things were wired before I changed the wiring harness (because I took pictures and followed them), but I could have effed up. First of all, there is a 3 prong connector at the bottom left of the photo with a dark blue and medium green wire connected to it, that has an empty tab. What is this (I can't seem to find it on my wiring diagram), and what wire belongs on the empty tab?
Secondly, the ground wire connected to the wiper motor looks like it doesn't belong there. It has a locking tab on it like the red-with-a-white-stripe wire, but isn't in a connector like that one is.
Thirdly, I'm getting voltage on the light blue wire in the 1-2-3 connector, where I think I should be getting ground.
Any ideas?
Any ideas?
Second, you definitely need that tab grounded. The connector may not be original, as it looks like the PO worked on the wiring a little bit.
Third, when the wiper switch is off, the blue wire shouldn't be grounded. When the switch is on low and high, it should be grounded.
If moving the wiper switch doesn't work to ground the blue wire, either the switch is bad (or ungrounded) or the circuit is open between the switch and the motor. In that case, make sure the relay clicks when the key is on (engine off) and you move the wiper switch between off and on to try and isolate the issue
New pic:
Any ideas?
Ernie
Do you have a '70 car? Can I get a picture of the connections at the three prong connector near the wiper motor?
Thanks.
PK
Thanks.
PK
Here is a picture of the connections, let me know if there is anything more specific you want.
Is the relay clicking when you move the wiper switch? That will help narrow down where the issue is.
I know the relay works because I have heard it click when I flip the switch. But honestly, I have screwed around so much recently that I need to re-test to say for sure that it does in the current wiring. I will try to get to that tonight.
Thanks.
PK
Just an idea..
Thanks.
PK
Also, JimT makes a good suggestion. Make sure that the motor ground is actually grounded and that the yellow and red wires to the motor have 12V when the car is on (engine can be off) and the wiper door is up.
Just an idea..
I just tested to see if the relay clicks when the switch is thrown. I connected the battery (have been leaving it disconnected due to shorting problems that I think I am past), put the key in run, car definitely has power (courtesy lights came on, clock started running), wiper door is open, I could not hear a click of the solenoid when turning the switch to slow. I have tested the relay based on Willcox videos (as well as the motor and switch), and it tests as good. Any help there is greatly appreciated.
The wiper relay not clicking is usually a symptom of a bad switch ground. If your gauge bezel is broken like many others, you will need to run a separate ground wire to the switch. The beginning of this thread illustrates this well: https://www.corvetteforum.com/forums...-question.html
The wiper motor won't do anything until this relay works, so that should be done first.
First, tonight's homework completed:
Ground: Reconnected as in my post #29. The plain black wire definitely tests as ground (less than 0.1 ohm to the negative connection at the battery). Full battery voltage at the yellow and red wires.
I will check the switch ground now.
Thanks!
PK
