Wipers, one last try:
Old Jul 12, 2017 | 08:06 PM
  #41
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
OK, you guys are right. I have the wiper switch hanging out of the dash since I have the center console apart (from checking the switch and relay), so the switch was not grounded. So, I ran a ground wire from the switch housing directly to the negative battery terminal, and ran some electrical tests again.
The ground at the wiper motor still tests ground. The yellow and red wires still test as full battery voltage. So that is good.
However, I found myself right back where I started. If you look at post #21 where Willcox has added letters to my picture, look at connection A. The side with the red splice shows full continuity to ground, but the other side shows full battery voltage. This is the dead short I have been dealing with the entire time. Any ideas here?
Old Jul 12, 2017 | 08:52 PM
  #42
Derrick Reynolds
OK, after extensive screwing around, the wiper motor ran in slow and fast speed, and parked, with the key in the position turning it backwards from off. I'm not even sure what that is called. It would not run at all in the on position. Any ideas there?
Old Jul 13, 2017 | 07:56 AM
  #43
Derrick Reynolds
I got it working with the key on. Thanks for all the help!
Old Jul 13, 2017 | 08:33 AM
  #44
D_Williams's Avatar
D_Williams
That's great!
Do you remember what you did to get it working? Both for just accessory (the key turned backwards) and for key on
Old Jul 13, 2017 | 11:45 AM
  #45
Derrick Reynolds
Originally Posted by D_Williams
That's great!
I suspect the motor not working with the key on might have been a brain cramp on the part of my assistant. It worked just fine for me when she left the garage. I think the problem all along has been the ground at the switch panel, because it worked last night when I ran a ground wire from the screw hole on the switch panel directly to the negative side of the battery.
I now want to replace the ammeter before I put everything back together. Willcox had a great instructional on that one I saw a few years back, but I can't seem to find it on their site at the moment. If anyone has a link to that, I would really appreciate it.
Never mind on this one. I got a little smarter with the search function, and found it in seconds.
Old Jul 14, 2017 | 01:42 PM
  #46
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
PK glad you got it fixed.. I'm still out of town and I'm glad D help pick up my slack..
Ernie
