Understanding Block numbers
Old Jul 12, 2017 | 03:00 PM
Davpmars's Avatar
Davpmars
Default Understanding Block numbers
My father had a corvette restoration business for years and years and he has a number of old corvette blocks sitting in his garage. I'm trying to understand what the numbers mean that are stamped on the block...
For example... F0627RF 3119311
My research says that F is for Flint Michigan. What is a "V" for?
0627 means that it was assembled on June 27.
RF describes the engine options. Where could I find a list of these code options?
3 stands for the year 63. What if this number was a "9"? how would you distinguish if a "9" meant 59 or 69?
119311 stands for the sequence the block was made and numbers started at 100001 so this would be block number 19,311 in 1963.
I know there are a lot of questions in there. I appreciate your help!
Old Jul 12, 2017 | 03:23 PM
JC68's Avatar
JC68
Sounds like you have a pretty good understanding already.
For 1966 and before F = Flint, after V = Flint.
This site will list most of the engine codes:
http://www.nastyz28.com/sbchevy/sblock.php
The engine codes will help you determine 59 from 69. They were frequently changed. You can also use the bock casting number to help distinguish between 59 and 69. The above website will also have these listed.
Only thing I would change on your description is of the number 119311, this is the car sequence number (shortened vin) and not the block sequence. It is the engine for the 19,311 Corvette produced that year.
John
Old Jul 12, 2017 | 03:34 PM
Davpmars's Avatar
Davpmars
John
I just took a quick look at that website, it seems like some good information.
What is the difference between the number that I listed (F0627RF 3119311) and a casting number? Why have 2 different numbers stamped on a block?
Old Jul 12, 2017 | 04:09 PM
JC68's Avatar
JC68
The casting number is not stamped but is cast into the block. It is found on the back flange by the bell housing. This casting number shows what rough casting was used to make the finished block from.
Casting numbers would change as design improvement were incorporated into the blocks. Sometimes a certain casting number was only used for a very short period of time and others were used for years.
The RF engine code could have been produced from potentially several different casting numbers as a year progressed.
John
Old Jul 12, 2017 | 04:17 PM
Alan 71's Avatar
Alan 71
Hi D,
The block casting number and date were part of the mold used when the block was cast at the foundry.
The casting number identifies the block before machining.
The date of course identifies when the block was cast.
They are typically on the top of the rear flange of the engine… just forward of the bell housing.
After the block want to the engine plant it was machined and assembled.
The Assembly stamp identifies what plant the engine was assembled at, when it was assembled, and in what hp and accessory configuration.
After the engine was shipped to an assembly plant the vin number of the vehicle it was first installed in was stamped on the pad.
Regards,
Alan
Added…. a couple of minutes too late.
A typical stamp pad on a 71 350 small block.
Typical 71 casting date on a 71 350 small block.
Typical casting number and casting' clock' location on sb engine.
Old Jul 12, 2017 | 05:29 PM
Davpmars's Avatar
Davpmars
Originally Posted by Alan 71
Hi D,
Regards,
Alan
This is great! Thanks for all your help.
One more question...
This serial number doesn't conform to what I know.
V1009HT 18S402101
V = flint
1009 = Oct 9
HT = 327 small block
After that I am lost...
Old Jul 12, 2017 | 06:19 PM
Alan 71's Avatar
Alan 71
Hi,
Here's the 'de-code' for the 68 VIN.
The block receives a 'partial VIN.
The full VIN de-code.
1 (First Digit) Make/Manufacturer. 1 – Chevrolet
9 (Second Digit) Model series. 9 – Corvette
4 (Third Digit) Engine type. 4 – V8 Engine (all types)
37 (Fourth and Fifth Digits) 37- Corvette Coupe / 67 – Corvette Convertible
8 (Sixth Digit) Model Year. 8 – 1968
S (Seventh Digit) Vehicle Assembly Location. S – St. Louis, Missouri
7XXXXX (Seventh thru Twelfth Digits) Plant Sequence Numbers.
Regards,
Alan
Old Jul 14, 2017 | 01:11 PM
bigredbrad's Avatar
bigredbrad
From: Lincoln NE Riding and Driving Corvettes since 1967.
V1009HT 18S402101
V = flint
1009 = Oct 9
To help clarify the second set of numbers. The factory did not stamp the full vin on the block since the first numbers (19467) were the same for the entire year (except the coupe or convertible designation as Alan listed above, which did not matter to the engine line). The 18S402101 would be the last part of the serial number of corvette #2101. The 8 means 1968, the S means St. Louis plant, the 4 always the same and means nothing in this case. 02101 was for the 2101st corvette produced.
Hope this helps
bigredbrad
Old Jul 14, 2017 | 01:13 PM
bigredbrad's Avatar
bigredbrad
Also, if you have any big block engines, the serial number and the engine code will be listed opposite of the small block on the engine pad. Big blocks have the engine code listed first and the vin derivative second.
bigredbrad
Old Jul 14, 2017 | 03:12 PM
Alan 71's Avatar
Alan 71
Hi D,
One last thing…. of interest?
In St.Louis the same stamp gang holder that was used to imprint the engine pad with the vin was used to stamp the case on the transmission.
Regards,
Alan
The partial vin gang holder, digit tray, hammer, and glove.
The Engine assembly stamp gang holder.
To Understanding Block numbers
