Vortec Heads
Old Jun 22, 2017 | 09:23 PM
truckerlary's Avatar
truckerlary
Default Vortec Heads
I acquired a set of 12558062 vortec heads that I'm considering installing on the 71 350 that I have in my c3. When I rebuilt the 350 I installed flat tops and was wondering with these heads what kind of compression ratio I'd be looking at by using these heads. Nothing exact just ball park, Thanks Larry
Old Jun 22, 2017 | 09:35 PM
'75's Avatar
'75
I'm guessing around 10 to 1 with the flat tops.
Old Jun 23, 2017 | 07:42 AM
L88Plus's Avatar
L88Plus
I built a 355 for my '97 Tahoe. Zero decked the block, .040 quench, 4 valve relief flat tops, 10.14:1. Works fine in my computer controlled engine.
Old Jun 23, 2017 | 09:10 AM
SH-60B's Avatar
SH-60B
Around 9.5 to 1 if you have not decked the block, pistons have valve reliefs, chamfered circumference.
Old Jun 23, 2017 | 09:33 AM
MN80Vette's Avatar
MN80Vette
I have a GM Performance 350 HO crate engine with Vortec heads in my '80. GM specs say 9.1:1.
Old Jun 23, 2017 | 10:28 AM
truckerlary
What are you using for intake? All the info I'm seeing is that a lot of intakes won't work due to hood clearance. I'm running a 75 with an 80 front clip.
Old Jun 23, 2017 | 10:33 AM
truckerlary
My pistons have 2 valve reliefs, very little chamfer if any and engine is bored 60 over. No block decking that I know of.
Old Jun 23, 2017 | 11:39 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
My 77 has a Performance Products Cyclone vortec intake manifold that fits with my stock air cleaner.
Old Jun 23, 2017 | 12:25 PM
BKbroiler's Avatar
BKbroiler
My 77, with Vortec heads, has an Edelbrock Air Gap manifold, 3/4 thick adapter, Qjet and a drop base air cleaner with 3 inch element under the stock hood - just barely.
Old Jun 26, 2017 | 12:20 PM
Richard Daugird's Avatar
Richard Daugird
Keep in ind the Vortec heads only allow for .450 lift cam(approx.). Comp Cams has a tool you can use on your drill motor and modify them at home if you want to use a high lift cam.
To Vortec Heads
