power steering control valve
Old Jul 5, 2017 | 05:55 PM
joelachette1's Avatar
joelachette1
4th Gear
Default power steering control valve
Is it possible for a control valve to stick or stop working while driving the car and if so will it cause you to lose control of the car
Old Jul 6, 2017 | 12:00 AM
7T1vette's Avatar
7T1vette
That's a really good question. Normally, vehicle engineering organizations put lots of effort into making such a component "fair-safe"; so my belief is that a control valve failure would be "hazardous" but probably would not cause you to lose complete control of the steering.
However, the real expert on the C3 steering systems is Jim_Shea, who worked for Saginaw Steering in that era.
Old Jul 6, 2017 | 12:07 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Lets look at this a little differently. Has anyone in a C3 ever had it stall, thus robbing the control valve of power? If so, did they slam into the first lamp post that they saw?
The piston will move in the steering cylinder with force from the steering wheel. Just isn't very pleasant.
Old Jul 6, 2017 | 01:12 PM
7T1vette's Avatar
7T1vette
I think the poster was concerned that a defective control valve might throw the car full-left or full-right without the driver being able to compensate.
Old Jul 7, 2017 | 06:40 PM
DUB's Avatar
DUB
I seriously doubt that it could fail to the point where you could not take control and still be able to steer the vehicle.
And that is assuming that the 'extend' and 'retract' hoses are CORRECTLY installed as designed,
I do know that even if the control valve is not 'balanced'...it may cause the car to steer to the left or right while driving..but not so much that you could not hold the steering wheel and maintain some control and be able to stop the car.
I have to agree with '7T1vette'..there are built in safety factors.
The ONLY time I have seen the steering wheel spin violently in one direction is when my ex-partner connected the 'extend' and 'retract' hoses incorrectly..and when the engine was cranked up...the steering wheel took off in one direction. THANK GOD when he cranked it...he did not have his arm going through the spokes of the steering wheel...because it could have LITERALLY ripped his arm off it was so violent. BUT...as I wrote...THAT was because the hoses WERE NOT installed as designed.
DUB
Old Jul 7, 2017 | 08:17 PM
Cavu2u's Avatar
Cavu2u
Joe,
I too believe this disastrous scenario would be virtually impossible. For if it were, I believe we would have witnessed one of the greatest automotive engineering mess-ups of all time (apologies to the Corvair), with fatal accidents all over the place.
Steve
Old Jul 8, 2017 | 03:33 AM
rebel542's Avatar
rebel542
I drove my 79 L82 4 Spd for a couple of years with belt removed. Like driving a car with manual steering. Good upper body workout.
Old Jul 8, 2017 | 08:36 AM
cagotzmann's Avatar
cagotzmann
Well here is my real world experience. Yes it is possible , but total lose of control I would say depends.
Driving my car at the race track and starting into a right hand corner @ 65 MPH as I continued into the corner all of a sudden the car steers to the right, I was forced to adjust to the left, the cars back end starts to come around. Next corner left hand turn no problem, next right hand turn same result. As I get to a point where the imbalance starts.
I Drive into the pits and check the steering. Standing still and steer to the right I got to a point where extra force turning right is applied.
After adjusting the control value balance everything is normal again.
So I am not sure how this part of the control value is designed, but if extra fluid is routed incorrectly it may be enough force that the driver may not be able to counter steer.
So I guess its the unexpected result which could allow the driver to lose control, but it depends on where and how fast you are driving.
To power steering control valve
