Can use some help with questions...
I have the AIM but feel it a little frustrating at times.....lol And I did check Wilcox for schematic on the hoses, but the closest I found was with the colored sheet for the 72.
Soooooo....
1-On the center actuator that would be on top of the trans tunnel that has an upper and lower port, I believe that the blue strip hose goes on the top and the red strip hose goes on the bottom...correct???
2-On the actuator that is attached to the heater box itself (on the left side of the box against the firewall), one line I broke, so I know where it came from and where it goes, but the other "L" shaped port, what color hose goes there??? Is it the tan color hose???
3-Does anyone know what the correct color the two heat shields under the firewall should be painted???
Thanks for any info or reference to the questions asked....
Appreciated.......Tom
Soooooo....
