One of the biggest things that is missed is the foam collar that goes on top of the bell housing between it and the trans tunnel. At least it's on the SB 4 speed cars. I would think it's on all the cars. What it does is deflect the engine compartment heat from going down the tunnel. Not sure how effective it is as I don't have A/C either. Something to check.
Keep in mind that your car was built in an era that had very poor heat barrier materials and if you are trying to get it to be comfortable like what it is like in current cars of today...you will have to upgrade the material in your car to aid in stopping the radiant heat.
Also you must check and see that firewall grommets and holes in the firewall are plugged.
Also your under hood weatherstrip seal that seals against the top of your cowl plenum area MUST be there because if it is not...hot air from the engine compartment can blow into your wiper cowl area and thus get into the car.
On the underside of your hood there should be a piece of weatherstrip that when the hood closes...it seals off the top edge of your cowl plenum.
IF you do not have this weatherstrip intact and sealing off this area....heated air form your engine compartment will get blown into the cowl area and thus get sucked into the cabin....thus resulting in more heat.
DUB
Would this apply to 73 and later models as well?
I am looking for ways to allow more air to enter and pass through the engine compartment. I'm thinking, with my limited experience, is that a limited amount of outside air enters the engine compartment, gets trapped and allows engine heat to build in the engine compartment even at highway speeds, adding heat in the interior. I'm trying to find ways to allow air to pass through the engine compartment as fast as possible and to pull engine heat out with it. By replacing my front plate with a grille I'll allow more outside air in. Removing and rearranging items at the front of the engine and in front of the side vents will allow heated air to exit with less restriction. I was considering, that if I extend the height of the center of my stock hood for air cleaner clearance and keeping the hood seal in place, it would allow additional heated air to flow out through the back of the top of the hood opening. Am I wrong?
