1970 Roadster console
I am new to these forums, I have owned my 70 for about 43 years and about 180K miles and she requires a few cosmetic enhancements and the console is one area that I am starting to work on. I took the interior out some time ago and am now putting it back, I was wondering if anyone has some advice on which parts go back into the console in which order? Thanks in advance.
Welcome!
43 years…. "just a moment in time"!!!
Are you asking about the shifter plate?
If so:
The heater defroster control should be put in place on the top of the console first. Make sure the proper electrical connections for the controller are in place… the lamp for the dial and the ground connection.
The ashtray should be mounted under the shifter plate. Make sure it's electrical connection and lamp are in place.
Then make sure the boot for the shift lever is in place (if it's a 4-speed).
Also check that the rear lens for the fiber-optics is in place and the cables are securely pushed into the len's tubes.
The shifter plate can then be put onto the console and the 4 screws in the plate's corners installed.
Finally the ***** for the vent levers can be installed.
Good Luck!
Regards,
Alan
Of course Alans great pictures help as always.
