Adaptability Question
Old Jul 27, 2017 | 11:59 AM
blanman61's Avatar
blanman61
Default Adaptability Question
78 L-48, Stock with all emissions removed. Vapor canister removed with vented gas cap.
Tired of the fuel smell in the garage and going to reconnect my vapor canister. My question is since there are no emissions connected can I use a canister from a 74-77 vette. Can buy original delco for about $60 which is cheaper than rebuilding my original, new purge valve, charcoal etc.
Have already tracked down & repaired other fuel leaks.
The earlier canisters only have 3 hookups which I think is all I need. Tank connection, to carb bowl & vacuum source.
Am I thinking correctly or am I missing something? Thanks,
Old Jul 27, 2017 | 01:24 PM
MelWff's Avatar
MelWff
If the tank connection in the engine compartment is blocked off the lack of canister is not your problem. Cars had vented gas tanks for years without having a gas smell. Are you sure you Quad doesnt have leaky casting plugs causing the gas to drain into the intake, assuming you havent a leak somewhere else?
You have looked at the fuel pump for leaks?
Old Jul 27, 2017 | 02:31 PM
blanman61's Avatar
blanman61
Yes the quad did have a leak at the throttle shaft. Had rebuilt, no longer a problem. Found and repaired couple of other leaks in the fuel lines. Car is black, after driving in hot sun then parking in garage is when get the fuel smell and can smell it at the cap
Old Jul 27, 2017 | 04:53 PM
MelWff's Avatar
MelWff
how did you find a vented cap for a 78? it sounds like the seal on the cap is bad.
Old Jul 27, 2017 | 05:45 PM
blanman61's Avatar
blanman61
I had an extra cap that i had drilled some small holes into.
Old Jul 27, 2017 | 05:55 PM
bazza77's Avatar
bazza77
my 77 when I got it had the engine line plugged off ,but the canister was still connected to the tank with the original cap and I had no smell
To Adaptability Question
