Need intake manifold gaskets?
Old Jul 29, 2017 | 05:51 PM
swag's Avatar
swag
Default Need intake manifold gaskets?
Hello all;
I've got a lot of projects going on with my car. It has been a lot of fun and am learning so much.
So, the latest problem I see is oil collecting at the bolts for the intake manifold gasket.
My car has never been rebuilt and it runs great (even better after Lar's touches to it).
I guess I could be loosing compression right?
Old Jul 29, 2017 | 06:02 PM
Alan 71's Avatar
Alan 71
Hi S,
Is it possible it's the bolts not the intake gasket?
Some of the intake manifold bolts protrude into the lifter valley so oil can 'wick' up the bolts and puddle on the intake.
There are various sealers available that are applied to the bolts to help control the seepage.
Regards,
Alan
Old Jul 29, 2017 | 06:28 PM
swag's Avatar
swag
Originally Posted by Alan 71
Hi S,
Regards,
Alan
Thanks Alan,
What you are saying makes sense. If the gasket was leaking wouldn't I see oil collecting around the gasket?
I just ordered Permatex 80011 Form-A-Gasket #2 Sealant.
When I do the radiator swap, it will be the perfect time to fix this too.
Hoping the bolts come off easy!
Old Jul 29, 2017 | 10:37 PM
Big2Bird's Avatar
Big2Bird
Regular Teflon pipe dope, the type in a can works fine.
Old Jul 30, 2017 | 06:29 AM
bazza77's Avatar
bazza77
yep looks like the oil coming up the thread , take them out and wire wheel them until they are spotless , clean them with some thinners and put your sealer on and carefully put them back in .
Old Jul 30, 2017 | 04:45 PM
7T1vette's Avatar
7T1vette
Be careful not to put a LOT of sealant on the threads. Excessive sealant can prevent the bolt from completely seating in place. Just wipe some on the bottom 3-4 theads and have none on the end of the bolt. That will get the job done.
Old Jul 30, 2017 | 09:01 PM
JayRay's Avatar
JayRay
I had the same thing with mine. Put some Sealer on the bolt and put it back in and it fixed the problem. No more oil on the intake.
Old Aug 2, 2017 | 02:13 PM
Bergerboy's Avatar
Bergerboy
I have a similar issue.
I'll try this fix as well, while I'm changing the valve covers and gaskets
To Need intake manifold gaskets?
