Led lamps
Old Jul 31, 2017 | 07:59 PM
fake's Avatar
fake
Default Led lamps
Does any one know were LED replacement lamps for interior lighting can be bought? 1977 vette
Old Aug 1, 2017 | 10:00 AM
TimAT's Avatar
TimAT
superbrightleds.com
They have replacements for just about all incandescent lamps.
Old Aug 1, 2017 | 08:19 PM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Is it much of a job replacing the speedo and tach bulbs to LED?
Old Aug 1, 2017 | 10:23 PM
TimAT's Avatar
TimAT
Changing the bulbs is easy. Getting to them is another story. And swapping to LED's, polarity is an issue unless you can find LED's that don't care. You need to install them and test before you put the dash back in.
Old Aug 2, 2017 | 03:06 PM
terry82's Avatar
terry82
I got led interior light bulbs from Walmart. the dash lights I would get from superbright
Old Aug 2, 2017 | 03:29 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Amazon.com just look up the 3 or 4 digit code of the individual bulbs you're after and then search for highly rated ones on Amazon.
Be sure to buy bulbs of the same color as the housing for max brightness. Also note that the contact wires on many of the LEDs are VERY small so you'll want some dielectric grease.
Also be sure to buy the same temperature (yellow vs. blue tint to the white light) for all of your white bulbs and as a final recommendation, check the length of the bulbs some of the really bright LEDs are too long for some of the C3 bulb housings (I found this out the hard way).
Final, final note: Don't replace your turn signals with regular LEDs; they won't work with a simple bulb replacement swap as they don't draw enough current to actually blink.
You will be happily surprised at just how cheap LED replacement bulbs are through Amazon this way.
Old Aug 2, 2017 | 03:40 PM
cor66vette's Avatar
cor66vette
I replaced the rear directionals only and they work fine. Front AND rear, n/g.
Old Aug 3, 2017 | 12:55 PM
7T1vette's Avatar
7T1vette
Quality of LED interior bulbs on the internet is a crapshoot. Some don't work; the size of the barrel on the bulb may be wrong, etc., etc.
Some auto part stores are now selling them; at least you have a way to take them back if you are not satisfied.
LED bulbs dim very little with the dash dimmer adjustment; then they just go out if voltage is too low. For proper dimming, you need a PWM module to connect to LED bulbs in the same 'string'.
I tried going this route. In the end, I just bought new incandescent bulbs and will be satisfied with getting 5-10 years out of them before doing it again (if I'm still around!).
Old Aug 3, 2017 | 12:57 PM
ignatz's Avatar
ignatz
Originally Posted by TimAT
superbrightleds.com
My endorsement for superbright as well. They all worked. I have some suggestions for anybody replacing all of their incandescents, however.
Old Aug 3, 2017 | 01:45 PM
LT1M21Vette's Avatar
LT1M21Vette
Pro tip, get an electronic relay, and change all turn signal bulbs with LEDs, and never look back.
cf12anl-01-led-bulb-electronic-flasher
Old Aug 7, 2017 | 06:49 PM
george2066's Avatar
george2066
same with me on LED, all trouble, falling out of sockets, pulling my hair out with the tach/speedo in and out , real PIA. went with stock bulbs, new headlight switch, looks good at night
Old Aug 7, 2017 | 07:30 PM
BlackC3vette's Avatar
BlackC3vette
Very true, I finally pulled the cluster out on my 80. Also, I marked the polarity of the LEDs because of the problem putting them in reversed.
Old Aug 7, 2017 | 08:14 PM
metal tech's Avatar
metal tech
Superbrite LED's has a great selection but I have found that Autolumination has some bulb designs that Superbrite doesn't have. In the 194 size Autolumination has some that have a wider beam pattern that work better in the small space of gauges. I think between both of these places you can find what you need. Second on the electronic flasher, get one N go LED for turn signals.
Old Aug 8, 2017 | 01:35 PM
carriljc's Avatar
carriljc
You may want to consider converting to strip lighting.
Not sure how much different a 77 is from the earlier C3s.
Here is my story:
https://www.corvetteforum.com/forums...-and-tach.html
To Led lamps
