Does anyone rebuild steering gearboxes anymore?
Old Aug 2, 2017 | 11:02 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Vette magazine
The latest issue of Vette magazine has an article on how to rebuild the steering boxes of the C-2 and C-3 vettes. It is step by step and they even give info on where to purchase parts. If you don't want to do it yourself, all of the vendors mentioned will do a great job for you. I used Van Steel and the box works as new years later. I really like to pay close attention to brakes and steering. Jerry
Old Aug 2, 2017 | 11:38 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by Scottd
Vansteel lists their rebuild price as over 400 bucks, I can buy refurb for 120. I havnt dug much deeper into the other sites. Seems rebuilding costs 2X more than a restored unit? What am I missing here?
Scott, I believe you may have misread the page I directed you to. A new steering box is $404.99
The cost to rebuild your box is actually listed as $189.99 https://www.vansteel.com/index.cfm?f...p=1820&ID=3701
Without a doubt Gary does a terrific job. Clearly it is your call.
GUSTO
Old Aug 2, 2017 | 02:02 PM
gleninsandiego's Avatar
gleninsandiego
Gary R just did mine
Ridiculous attention to detail and documentation.
I needed new parts which he had as well.
Glenn in San Diego
Old Aug 2, 2017 | 11:57 PM
RickDett's Avatar
RickDett
How do you know it needs to be rebuilt? Did you try to adjust it? Maybe someone could post the procedure for you to adjust it. Sounds like you are planning to remove it yourself.
Old Aug 3, 2017 | 12:45 AM
Big2Bird's Avatar
Big2Bird
I have rebuilt 3 or 4 using Gary's method and parts from Bair's.
You HAVE to have an 0-30 inch pound dial type torque wrench to set these up correctly, or you risk tearing up the gear set. If you do, they are done.
The torque wrench set me back $150.
Old Aug 3, 2017 | 12:46 PM
7T1vette's Avatar
7T1vette
There is considerable difference in buying a "rebuilt" steering box from the local auto parts store and having one rebuilt by an expert in the business. The 'store' rebuilt unit is a reassembly of random parts removed from other boxes and cleaned; the "rebuilder" is likely a low-dollar/hour worker in a foreign country. In the words of a very wise man:
"You get what you pay for..."
If your box is not worn out, open it up and remove as much grease as you can; refill with good quality synthetic grease (leave air space for grease expansion due to heating); clean the outside and paint if you like. Adjust the lash screw [properly] if you need.
Otherwise, have a pro rebuild your old one or buy a new one. The Borgeson box is nice (and expensive), but it is likely no better than an original box that is properly set up.
Old Aug 3, 2017 | 01:00 PM
jb78L-82's Avatar
jb78L-82
A properly set up OEM recirculating ball GM steering box 16:1 ratio can be very good especially with Gary R's modification with the custom olite bushing on the steering shaft. Because of this change to the OEM box by Gary, I HIGHLY recommend Gary for this service plus his impeccable work!
The advantage of the Borgeson box is the 12.7:1 steering ratio which is obviously much faster and the Borgeson box eliminates potential slop from the power steering ram and PS balance valve from GM with the OEM steering system.
Old Aug 3, 2017 | 05:05 PM
Scottd's Avatar
Scottd
GUSTO
Good catch brother. I still have the old gear box, Im really going to have to consider this option. Having it rebuilt seems to be only slightly more expensive than a Vatozone over the counter part.
All things considered, I cant think of anything else that would be causing this problem. Everything except the gearbox is new (even the rag joint). Guess Ill spend 200 bucks on a rebuild.....hope it works because Im out of other options.
Old Aug 3, 2017 | 06:04 PM
Dynra Rockets's Avatar
Dynra Rockets
[QUOTE=Scottd;1595284206 Guess Ill spend 200 bucks on a rebuild.....hope it works because Im out of other options.[/QUOTE]
Did you already adjust it?
Old Aug 3, 2017 | 10:00 PM
Scottd's Avatar
Scottd
I went to the car tonight and loosened the nut and played with the screw. It was tight to run up or down, so I fiddled with it back and forth a few times. (Maybe old crusted grease?) I just kept running it out until I felt the slop go away in the wheel and then backed it off a hair. I want to say it took about 3/4 of a turn which is kind of excessive. My concern is over tightening it. I think Ill try and drive it with this adjustment. If I feel any kind of improvement, I may just try and pop the top off, re-grease and adjust again. If theres no improvement.... its off to be rebuilt. Im not against spending money on a rebuild, I just want to track down the problem first.
Old Aug 4, 2017 | 08:42 AM
7T1vette's Avatar
7T1vette
If you over-tightened it, the steering wheel will not return to center on its own. What you want is to remove any 'slop' while not preventing it from freely returning to center after the vehicle makes a turn.
If the internal gear is worn in the center (but not in either direction), you can adjust to 'minimize' the slop....but you won't be able to eliminate it. That's when a rebuild is necessary.
Old Aug 4, 2017 | 01:19 PM
Scottd's Avatar
Scottd
Excellent answer. The wheel has never returned to center on its own. My adjustment last night did take up quite a bit of play, but the 'fail to return to center' is still present. Ill try lowering the screw a 1/8 turn at a time and see if I find the sweet spot....but like I said, its always had a return to center issue. Assuming my alignmnet is withing specs, does that mean there is internal wear/damage to the innards of the box?
Old Aug 4, 2017 | 03:17 PM
  #33
Dynra Rockets
Your steering wheel will also fail to return to center is you are running little caster. More caster = more centering.
Old Aug 4, 2017 | 06:24 PM
  #34
7T1vette's Avatar
7T1vette
If the steering box has not been maintained properly (no lube change over 40 years of use), then it may be worn in only the center of its range of travel. Thus, steering will work fine in either direction, but there will be slack in the system when the wheel is centered.
Once the steering wheel returns as it should, you will have to be the judge of whether [or not] there is too much slop when centered. If you deem it to be excessive, I suggest that you have it rebuilt by Gary or other reputable rebuilder.
Old Aug 4, 2017 | 06:30 PM
  #35
Scottd's Avatar
Scottd
Thank you. That helps immensely. Now I just need to find time to get it aligned again. I HATE letting other people work on my car.
Just to make sure, you are saying I need MORE (positive) caster? Is that a shimming operation I can do at home without fear of really screwing up the alignment?
Old Aug 4, 2017 | 06:58 PM
  #36
Dynra Rockets
It will affect toe so an alignment is recommended. PLus you really want it equal side to side otherwise it will want to turn in one direction easier than the other
Old Aug 5, 2017 | 05:53 PM
  #37
Scottd's Avatar
Scottd
Its tough to finds shops around here that will work on older cars, nonetheless a Corvette. Guess Ill be looking for a alignment again.
To Does anyone rebuild steering gearboxes anymore?
Old Aug 6, 2017 | 11:01 AM
  #38
A8skyhawk's Avatar
A8skyhawk
It's already been said, but Gary R just did mine a few months ago... couldn't be happier. I've not experienced his level of service for the price on anything Corvette related. Highly recommended.
Old Aug 6, 2017 | 12:31 PM
  #39
jim2527's Avatar
jim2527
I'll be polite. Gary will never see a penny of my money.
Old Aug 6, 2017 | 01:47 PM
  #40
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Did he build something for you and not make good on it or is this just personal?
The OP was looking for advice on builders and customers with real experience.
How does this comment help him?
Gary just finished my Original Super 10 and it was a precision job with copious communication.
I have never heard anyone bad mouth him.
Now another builder on CF has a youtube video complaining about his work. Just to be clear....the video is NOT about Gary but is about another vendor here on CF. Sorry for the confusion.
So please elaborate so OP can make an informed choice.
Txs
