C3 Shifter Badges
Old Aug 3, 2017 | 10:26 AM
ballkiddy's Avatar
ballkiddy
8th Gear
Default C3 Shifter Badges
I just bought a 1975 C3 for next to nothing. It had been sitting for 10+ years in a guys barn but was well preserved by a quarter inch of dust. Upon inspection, I noticed that the plaque under the shifter, says 350 C.I., 350 H.P., 11:1 Compression. I cant find any record of this being made in the 70's. Has anyone heard of this model/motor combo?
Old Aug 3, 2017 | 10:32 AM
Alan 71's Avatar
Alan 71
Hi bk,
Welcome!
The L-46 engine which was an option for the 69 and 70 model years was rated at 350 hp and had a 11:1 compression ratio.
Very nice sb engines!
Regards,
Alan
Old Aug 3, 2017 | 10:56 AM
Bergerboy's Avatar
Bergerboy
Your '75 must have been "Re-Badged" or Re-Consoled at some point with one from a '69 or '70.
Some may call that false advertising.
I believe the HP ratings of the SB dropped year-by-year in the early '70s, until (IMO) it got to the point of being too embarrassing to etch a sub-200 HP number into a plaque, and they canned it altogether!
Old Aug 3, 2017 | 11:45 AM
ballkiddy's Avatar
ballkiddy
8th Gear
I was wondering if it might have had a different console installed. I'm completely new at this, so forgive the "elementary" questions, but would the VIN on the motor tell me the specs? I'm not even sure if this is a factory motor, the VIN on the dash has a J in the fifth position, which I read is the L48 engine. So I have to believe that something has been changed, either with the plaque or the motor. Nothing on the engine appears or sounds stock. (headers, high rise, holley carb, distributor, nice sounding cam) I will post some pictures once I pick it up from the tire shop. They were dry rotted, and the brake pedal was on the floor, but cranked pretty quick with a fresh battery.
Old Aug 3, 2017 | 12:26 PM
Alan 71's Avatar
Alan 71
Hi bk,
You can take a look at the 'stamp pad' on the engine block right in front of the right side valve cover.
On that pad will be 2 stamps.
The first will indicate at which engine plant the engine was assembled, the date it was assembled, and the application for which it was intended and configured. (horsepower, carburetor, transmission.)
Secondly, there will be a stamp with the partial VIN sequence of the vehicle this particular engine was first installed in.
So take a look there to see what might be visible.
Regards,
Alan
Old Aug 3, 2017 | 12:41 PM
ballkiddy's Avatar
ballkiddy
8th Gear
Thanks a million!
Old Aug 3, 2017 | 03:13 PM
Haggisbash's Avatar
Haggisbash
Hi ballkiddy, if you are lucky maybe the engine combo now in the car will match the plaque:-)
Old Aug 3, 2017 | 04:57 PM
v2racing's Avatar
v2racing
I'm guilty of rebadging my 75 Vert. With the car having almost nothing stock in the engine, tranny, driveline, steering and suspension, I just couldn't see putting the lowly L48 badge back on it, so I picked the baddest small block they ever put in a C3, the 1970 LT1 badge.
Mike
Old Aug 3, 2017 | 05:06 PM
ballkiddy's Avatar
ballkiddy
8th Gear
hopefully that's what happened here!
Old Aug 3, 2017 | 09:17 PM
mrvette's Avatar
mrvette
When I put my custom injected roller 355 engine under there some 20 years ago, I had a awards/plaque shop cut/engrave new inserts for the console...engine and ODrive trans....it was a 4 speed muncie, but now an auto 4 speed 200 4r and I have a Hurst shifter arm with an 8 ball on it.....see pix below....
Old Aug 4, 2017 | 12:32 AM
Patro46's Avatar
Patro46
I too am guilty of re-badging my 74 L-48, but I simply couldn't handle a 190 hp L48 staring at me on the console, let alone what was under the hood, so I changed it up a tad...
Old Aug 4, 2017 | 06:15 AM
scrappy76's Avatar
scrappy76
I assume you have checked the vin of the vehicle and it is saying it's a 75. I assume it is a plastic front and rear bumper. Load up some pics, would love to see this vette.
Old Aug 4, 2017 | 09:38 AM
ballkiddy's Avatar
ballkiddy
8th Gear
Default pictures
The exterior pictures were taken prior to it being parked in the barn some time ago I think, the interior pics were snapped while I was there. I've replaced the tires, got to slap in a drivers side window motor, replace the headlight vacuum lines, tach doesn't work, two new front calipers, master cylinder, ac compressor leaks from the back, and I believe it needs a ac blower motor. Cold air comes out, but not very hard. There are three wires by the blower motor that are taped together I need to run down.
Old Aug 4, 2017 | 11:06 AM
SteveG75's Avatar
SteveG75
Car looks nice. Definitely some mods have been done.
Just from the photos, I see:
- Aftermarket hood.
- Possibly new front bumper cover (bumperettes on either side of license plater should be black on front portion, not body color)
- Center gauge console painted red? Should be black.
- Center console red (either black or woodgrain).
- Door trim painted red.
Old Aug 4, 2017 | 03:51 PM
raydog9379's Avatar
raydog9379
Go big or go home.
I'm kinda glad my 78 didn't come with a plate.
Old Aug 8, 2017 | 09:37 AM
ballkiddy's Avatar
ballkiddy
8th Gear
so I did what Alan 71 said and went out in the garage last night, wiped off some grime and tracked down these numbers. On the front of the block I found a 15S425428, and a VO 123CHB. Which I think I decoded as a 1975 350 L48 engine, also had 3970010 stamped on the rear near the firewall. The 425428 matches the last numbers of the car's VIN....so I think this is the original motor! Which is cool because the guy who had it chilling in his barn said it was a "crate motor" that was put in 15 years ago.
Old Aug 8, 2017 | 09:42 AM
ballkiddy's Avatar
ballkiddy
8th Gear
here are some photos of the engine. I've got some loose wires by the passenger side firewall, I think they may have something to do with the ac blower motor? does anyone recognize them?
Old Aug 8, 2017 | 01:28 PM
jim in oregon's Avatar
jim in oregon
Originally Posted by raydog9379
Go big or go home.
well, I have the lowly 350, wRochecter qjet 4barrel L48 in my '78.Originally 185 hp.
SINCE new..it has real performance headers true dual exhaust, no cat converters..but essentially still an L48. Probably puts out closer to 210 hp..but I really don't care about the number....still goes quicker and runs faster than the laws (or my common sense)allow or require.
I put L48 emblems on my hood w/3M tape..and had a console plate made by Corvette mods which reflects the original specs on the engine-drive train.Affixed it to the ash tray cover. on the console with 3m double sided emblem tape..
jim
To C3 Shifter Badges
