mystery smoke
Old Aug 5, 2017 | 08:41 PM
MQB's Avatar
MQB
1st Gear
Default mystery smoke
79, L48 automatic. Puffs of smoke during highway driving, coming from a/c vent (not constant and never before today). Darkish smoke that quickly dissipated, lost a gauge in the dash console directly below at same time (not sure if related).
Thanks in advance!
Old Aug 5, 2017 | 10:11 PM
righthanddrive's Avatar
righthanddrive
Check your fuses for the gauge problem. You may have fried a wire, but I don't think it would come through your vent
Old Aug 5, 2017 | 10:20 PM
7T1vette's Avatar
7T1vette
Some of the gauges have a 90 ohm wire-wound resistor on them. If one finally burned thru (age will get everything, eventually), there might be a small bit of smoke/smell and then that gauge would not work (or not work properly). I believe the fuel gauge had such a resistor on it. Not sure what other gauges might have had them.
Check Willcox's info site. They have lots of descriptive info and photos of gauges/wiring. They also may be able to provide better info on other possibilities for your symptoms.
To mystery smoke
