When I try to pull or push the headlight override switch under the dash it wont move and it won't raise or lower the lights. The lights will go up and down when I pull the headlight switch though. Any idea what could be causing this?
Thank you.
The switch is designed to block vacuum on the small hose side. So if you pull it down and the lamps don't open I'd have to say the switch is defective. You stated the switch won't move.... it should if you pull hard enough.. (unless it's down already and just not working, in that case push it up and see if it moves). Remove the hoses from the switch, couple them together and then pinch off the hose with a pair of needle nose pliers.. If the doors open replace the switch.
Or an even simpler test would be the remove the switch and pull it downward.... then try to blow through it... if it hasn't blocked the switch then it's defective.
Now a quick fix... You can pull the **** real hard and it will pull apart.. Then lubricate the o-ring that you'll see with some grease, then re-install it.. I'd bet this will fix the issue unless the O-ring is bad.
Willcox
Hi Len,
No.
When the stalk is pulled down the headlights open and remain open under all conditions. (Regardless of whether the headlight switch is pulled or not.)
It really can't prevent the headlights from opening when the headlight switch is pulled.
It DOES require that the headlight relays and actuators operate normally and that there is a vacuum supply.
Regards,
Alan
Hi Len,
Replacing the hoses may seem to be a good idea but the chance of it helping anything is quite slim.
I'd think you could better spend your time by trying to make sure you have a good vacuum supply at the relays and actuators
You might need to check the headlight switch…. since it controls both relays and both actuators and since neither side is opening it could be the switch.
Have you done anything to the car recently that may have caused this problem?
Have the headlights been working normally?
Did you do any work under the dash or up by the headlights that may have dislodged a hose?
If you want to check the hoses you can actually just cut about 3/8" off the end of each one and put it back in place. This gives the hose a 'fresh' sealing surface…. and accomplishes just about everything a new hose set does.
Regards,
Alan
If the lamps open and close when you pull the headlamp switch the system is working fine and your problem is probably just the over-ride vacuum switch itself.
Now I'm confused... When you pull the headlamp switch do they open?
So your headlights go up and down with the headlight switch? Correct?
And your headlights DON'T go up or down (or just up or down) using the override switch under the steering column? Correct?
Just trying to sort out your problem so we can figure it out.
Hi Len,
Would you consider reversing the 2 large hoses (red and green stripe) that run from the relay to the actuators?
If the headlight now opens but won't close you'll know you have a relay problem. Red to the rear of the actuator… curved pipe, green to the front of the actuator… straight pipe.
You can reverse the hoses either at the relay or the actuator.
It's odd that they both were working and now both won't close.
What year is your car?
Does it have one or two headlight relays?
Regards,
Alan
This is a 71,
A relay for each actuator.
2 large hoses running from the relay to the actuator.
The large hose in the center of those 2 is the vacuum supply to the relay.
I used a vacuum pump on the green hose and the lights will rise up.
There is another small hose that t's off to each relay. It has vacuum when the headlight switch or orveride is closed but no vacuum when either are in the On position?
So how does the relay get the signal to send vacuum to the red or green hose for opening & closing?
Hi Len,
The relay receives the vacuum (control) signal through that small hose.
The small hose should be attached to the short straight pipe on the side of the relay's can.
The headlight vacuum system has 2 sides:
Control…. filter, check valve, headlight switch, over-ride valve, relays, small hoses.
Servo…. large hoses and actuators.
The control system signals the actuators to open or close.
Regards,
Alan
The 'fail' position for the headlight is OPEN. No vacuum….headlights open.
That why pulling the override down should open the headlight doors.
