Steering Column Upper Bearing Preload Cup?
Old Aug 10, 2017 | 11:46 AM
Street Rat's Avatar
Street Rat
Default Steering Column Upper Bearing Preload Cup?
I have an '81 T&T column that I am working on.
My column did not have the part under the spring in the photo.
Is this part used on our columns? If so it looks as though I'm missing it.
Old Aug 10, 2017 | 04:12 PM
Big2Bird's Avatar
Big2Bird
This might be it on the bottom, but inverted.
Old Aug 10, 2017 | 05:55 PM
Street Rat's Avatar
Street Rat
I believe I see it between the steering wheel and wiring for the turn sign switch. It's at about 4 o'clock.
Old Aug 10, 2017 | 06:19 PM
TimAT's Avatar
TimAT
Yep. That has to be there so the spring has a seat.
And I'm curious-- what is the diameter of your steering wheel?
Old Aug 10, 2017 | 06:24 PM
Street Rat's Avatar
Street Rat
Boy this steering column job just blossomed into a...
I guess I'll gut that bitch tomorrow AND as usual I'm WAITING ON PARTS!
Old Aug 10, 2017 | 06:48 PM
TimAT's Avatar
TimAT
Are we havin' FUN yet? LOL
You can almost build the full column before you need that part.
Old Aug 10, 2017 | 06:58 PM
Street Rat's Avatar
Street Rat
I just did build the full column WITHOUT that part. Someone prior to me left the damn thing out.
Old Aug 10, 2017 | 07:08 PM
TimAT's Avatar
TimAT
You could assemble, put the column back in the car, then just pull the wheel when you get that cup. Just a thought.
Old Aug 10, 2017 | 07:13 PM
Street Rat's Avatar
Street Rat
The column is in the car. No turn signals or horns. So I was going back into the column anyway.
Old Aug 13, 2017 | 05:24 PM
Street Rat's Avatar
Street Rat
The part I received was not the correct size. I didn't have that piece in my column to begin with. It's been working that way for the time that I have owned it. So I reassembled the column without it.
Now I'm fighting a turn signal switch issue. But that is another thread.
To Steering Column Upper Bearing Preload Cup?
