Sure, fix one thing end up chasing other issues. I swear working on these cars is like eating popcorn.... can't fix one thing without uncovering another issue.
So I fixed all my instrument lights. Even fixed the dreaded fasten seat belt warning light.
Had a vacuum issue with the lights, fixed that. BUT now the headlight warning light stays lit.
SO up with the lights, and when I look for the warning switches, I sure do find them..... BUT they are just hanging down - they aren't attached to anything. Both are broken anyway. Seems that the threaded post that "should" be on the rear of the switch is broken off on both.
My question is where do they attach to the assembly? Picture would be great.
I'm going back down under to see if the threaded part just happens to still exist somewhere, but I don't really know where to look.
Hi Len,
The plastic threaded end of the switch has sometimes been broken off the switch's body.
Normally the switch extends through the link and is held in place with a thin nut.
Regards,
Alan
This is a switch taken apart to repair…. you can see the treaded 'snout' that goes through the link and the nut tightens on.
Working on your car as you do, you really NEED a copy of the 1975 Assembly Instruction Manual (AIM). It has drawings of most of the installation for the vehicle assembly. Not nearly as good as Alan71's photos, but adequate to find what you need.
I have the AIM for my car. I do find it helpful, although it can be confusing at times. Page 382 (12C) shows the switch.
I wish there was a good INDEX of the AIM to make finding drawings easier.
Funny, I was at a corvette shop this weekend and I was asking about some interior console parts and even they had a difficult time finding things in AIM.
If you've been through it before, then AIM can be very helpful, but for a first go around "some" of it can be very obtuse.
When installing those switches you just snug up the nut enough so the switch doesn't move. If you over tighten just a bit the plastic lug just snaps off. That and knocking the switch with your hand while working under there is the main reason for requiring a replacement.
The AIM is confusing the first few times you use it. But, once you get the 'lay of the land', it's very useful. It doesn't have everything in it [only the work content performed at the final assembly plant], but it's a God-send when you are taking things apart or reinstalling them.
FYI--
The "Sections" index is at the front; that will get you close to most base-configuration topics. And the AIM is designed to show you how that base-configuration vehicle is constructed.
If you have optional equipment (auto trans, engine upgrade, power features, etc), those options are in the back of the book in alphabetical order of their option CODE (ie, LS5 engine). Those sheets show the differences from the base-configurations given earlier in the manual.
It takes some time/practice to get the hang of using the AIM. Once you understand what it is (and what it is NOT) and how to use it, you will get a lot of value from it.
Hi Rick,
Replacing the switch is pretty straight forward. You do need to be aware that the switch is plastic and so is quite fragile.
Access from under the front apron through the breathing holes is probably your best bet.
While pulling the electrical connection loose support the switch with your other hand.
Then use a small wrench to loosen the nut on the switch's threaded snout. Because the snout is plastic, the nut, (metal), is usually easy to get off.
The hole in the 'link' for the snout has an odd shape to it, so the new switch can only go in place in one orientation, and it can't 'turn' as you tighten the nut.
Tighten the nut and then support the switch again as you put the connector back in place.
The other side is the same routine!
Good Luck!
Regards,
Alan
Just my 2C FWIW.
Thanks,
Len
When I bought my '71 AIM years ago the vendor also offered index that works great.
If you look up from under the car at the headlight "buckets", have someone turn the lights on so you can see how the assembly operates. Be sure to KEEP YOUR HANDS AWAY from anything, just observe (wear safety glasses just in case).
If you're lucky the wires may still be attached. If not, and if the switches are missing, all you are looking for is a keyed hole where the switches go (one for each headlamp).
The wires plug into the ends of the switches and should be near the headlamps.
