71 Brake Problem
Old Aug 23, 2017 | 09:28 PM
gnkjoy's Avatar
gnkjoy
Default 71 Brake Problem
Replaced the master cylinder and complete system fluid on my factory power brake car with a Delco correct coded part. Could not seem to get it bled correctly; pedal was soft with too much travel. Drove the car for over a thousand miles and the pedal went even lower. The fluid level in the master cylinder never varied. I recently took it to a shop. All calipers and components were examined; no leaks found, no obvious defects. The system was flushed and bled. Very solid brakes, immediate pedal response. By 100 miles I was back to extreme pedal travel to the point the brake light came on. Took it back two more times. Each time there was no fluid loss but air in both rear calipers.
It would seem to me to indicate a master cylinder problem. What I don't understand is how air is getting into the system, without any fluid loss/leaks.
Appreciate any help/solution. Car is unsafe to drive.
Old Aug 23, 2017 | 11:18 PM
cagotzmann's Avatar
cagotzmann
If the brakes worked great after a good bleed and now you have the same problem I would guess your calipers are pumping air into the lines due to rotor run out.
I assume you have the original lip seal design which requires a very low tolerance for rotor run out.
Have your rotors checked for run out. Try to get them < 0.005.
Old Aug 24, 2017 | 09:08 AM
gnkjoy's Avatar
gnkjoy
The information I have is that the pistons were sleeved with stainless steel inserts. Not sure how to check the lip seal design. I will proceed with having run out checked. Thanks
Old Aug 24, 2017 | 12:18 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Brakes
Have the shop put a dial indicator on the rotor and measure run out. GM says it should not be more than 8 thousands. I like to keep it below 4 thousands. If it is way out, consider replacing the rotors and measuring again. If it still not in specs, consider shimming the rotor and or switch to O-ring pistons in your system. I would do a search as there is a wealth of information about this on the C-2 and C-3 forum. Jerry
Old May 17, 2019 | 04:12 PM
gnkjoy's Avatar
gnkjoy
Still fighting this brake problem. Problem is isolated to the rear. Installed new rear rotors with no improvement. Checked runout and it was excessive. Finally found a shop that had an on-car turner. He claimed runout down to .001. Again after about 50-100 stops, brake pedal all the way to the floor. I am ready to install new rear calipers and brake hoses if I could be certain this would solve the problem.
Old May 19, 2019 | 09:03 AM
Fredtoo's Avatar
Fredtoo
Are you getting air out of the rear calipers after the 50-100 stops?
Both calipers, or just one?
Old May 19, 2019 | 09:56 AM
gnkjoy's Avatar
gnkjoy
Rear only, quite sure it's both sides.
Old May 19, 2019 | 09:58 AM
GTR1999's Avatar
GTR1999
I would buy a good dial caliper and mag base and check it yourself. If you have never done it before then you will need to learn to do it but it's not really hard to do. I can go over it with you if need help.
Old May 19, 2019 | 10:10 AM
Fredtoo's Avatar
Fredtoo
That sucks.
Make sure it is both sides, as that could help the diagnosis if it is just one side.
Can you trace the lines looking for dampness from the caliper to the master?
What about looking for dampness in the piston area. You may have to use a tool to peek where to boot seals onto the piston.
How old are the calipers?
It may be worth the cost just to replace them, vs spending a ton of time looking for other stuff.
They are reasonable in cost from Rock Auto.
Old May 19, 2019 | 02:25 PM
gnkjoy's Avatar
gnkjoy
Thanks, I do have a friend with lift, dial caliper, etc. This is how it we identified the runout problem. This is an example of "if it ain't broke, don't fix it." Went at least 3 years after replacing the master cylinder, just to get the correct coded Delco part, without a real problem. Just had what I considered excessive pedal travel, yet never went all the way to the floor. So, decided to see if that could be improved by rebleeding. Now I've gone two seasons having to re-bleed the rears each cruise/car show.
Any idea if the advertised new GM approved calipers have lip seals or O-ring type.
Old May 19, 2019 | 06:16 PM
Fredtoo's Avatar
Fredtoo
Did you put a brand new out of the box master on the car, or is it a 47 year old master cylinder?
Old May 19, 2019 | 06:22 PM
gnkjoy's Avatar
gnkjoy
New GM authorized Delco. Nothing wrong with old one, just did not have the code stamped in the housing.
To 71 Brake Problem
