72 BB car only goes in reverse
Old Aug 25, 2017 | 04:44 PM
BoatDaze's Avatar
BoatDaze
Cruising
Default 72 BB car only goes in reverse
My buddy just bought a 72 454 4 speed car. He drove it around the block and now it only drives uin reverse regardless of shifter position.
We of course are going to get under the car and check the linkage when we get from Carlisle, but any ideas? Has anyone seen this before?
Thanks!!
Old Aug 25, 2017 | 06:01 PM
CanadaGrant's Avatar
CanadaGrant
Thanks!!
It sounds like it needs the linkage adjusted. The reverse arm might not be coming fully out of reverse before the shifter itself is out of the reverse gate or the linkage or arm itself might have come off the reverse lever.
Old Aug 25, 2017 | 07:33 PM
'75's Avatar
'75
A back up camera would be a good idea, save your neck from getting sore. Just kidding, sounds like shifter issues.
Old Aug 25, 2017 | 09:31 PM
Big Block Dave's Avatar
Big Block Dave
Its going to be fairly obvious when you do finally get under there, but long story short, the car was shifted into reverse and that was the last time that the shifter conveyed any real information to the trans.
Either all the cotter pins fell out, or the mechanism inside of the shifter itself has broken.
Old Aug 25, 2017 | 10:17 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Does it have a shift interlock deal to the column? I don't remember which year that started.
JIM
Old Aug 25, 2017 | 11:51 PM
TeaEye's Avatar
TeaEye
Adjusting the linkage correctly is an art you develop. Take your time, use the lockout tool and adjust the rod lengths. It is a PIA. Be sure to install the spring retainers correctly.
Do search on linkage adjustments.....plenty out there.
Good luck.
Old Aug 26, 2017 | 02:18 AM
7T1vette's Avatar
7T1vette
Could be it was just its time to lock up due to wear, etc. Or...your buddy could have made a very poor shift that locked up the linkage.
Either way, it should be a simple fix, once you get under the car. If the linkage rods flop around when you wiggle them, you need new bushings and/or new pivot pieces.
Old Aug 27, 2017 | 11:20 AM
David Mc's Avatar
David Mc
Sounds like the back drive cable is stuck
Old Aug 27, 2017 | 12:17 PM
62corvette's Avatar
62corvette
What is a back drive cable? I am not familiar with that term.
Old Aug 27, 2017 | 02:11 PM
David Mc's Avatar
David Mc
Cable/linkage that goes from the transmission back to the steering column. It rotates the column shift bowl.
Old Aug 27, 2017 | 05:33 PM
Big Block Dave
...He drove it around the block and now it only drives uin reverse regardless of shifter position...!
This sounds like the shifter is not stuck, and can be moved, however gear does not change.
If that is the case, in some way, the shifter and the linkage are now operating independently.
Old Sep 26, 2017 | 04:41 PM
garyguinn's Avatar
garyguinn
isn't that only used on an automatic?
Old Sep 26, 2017 | 06:17 PM
maj75's Avatar
maj75
No. Used as part of ignition lock for steering wheel. Supposed to lock shifter in reverse on manual cars. Most were disconnected long ago. My car has the components but is disconnected as well.
Old Sep 26, 2017 | 06:18 PM
tracdogg2's Avatar
tracdogg2
Also 4 speeds starting in 1969
To 72 BB car only goes in reverse
