1977 Corvette Problem
Old Aug 26, 2017 | 02:37 PM
ssparks's Avatar
ssparks
1st Gear
Default 1977 Corvette Problem
My 1977 Corvette starts and runs great when cold. If I try to restart when it is still warm it has no power. I have replaced the starter, carburetor, steering column and continue to think it is an electrical problem. Any ideas.
Old Aug 26, 2017 | 03:42 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Check in with the folks on the C3 forum. A lot of good info there. Welcome aboard!
Old Aug 26, 2017 | 03:58 PM
Moving this to the C3 Tech section.
Old Aug 26, 2017 | 05:11 PM
REELAV8R's Avatar
REELAV8R
I had my neutral safety switch go out intermittently and i had the same symptoms. For whatever reason it was fine cold but once warmed up it failed, not every time but most times.
You could try moving the shifter in and out of "P" (assuming an automatic) then retry starting to see if it has any effect.
Old Aug 26, 2017 | 06:39 PM
sparky77's Avatar
sparky77
Could be a bad coil, when they get hot they will short out and lose power or not work at all.
Old Aug 26, 2017 | 06:50 PM
sullyman56's Avatar
sullyman56
On my 77 that had similar symptoms I replaced the ignition module and that took care of it.
Old Aug 26, 2017 | 08:23 PM
'75's Avatar
'75
Does your engine crank but not start, or not crank, like the starter won't turn it?
Old Aug 26, 2017 | 08:46 PM
HeadsU.P.'s Avatar
HeadsU.P.
I think Sullyman nailed it. The extra heat under the hood of C3s causes the "Modge" to expand. That breaks the circuitry, no spark until cool-down. Pretty easy to replace. Buy a new one, keep the old one in a rear compartment with the tools to replace it for emergency use.
Old Aug 26, 2017 | 08:52 PM
'75's Avatar
'75
The OP indicates no power, makes me think the engine doesn't turn over. I would suspect the module if it cranked but wouldn't start.
To 1977 Corvette Problem
