Shifter sticks in reverse.
Did you use the alignment tool to set up the linkage rods?
Did something come loose?
Here is a picture of the alignment tool It keeps the shifter from moving so you can adjust the linkage properly.
FYI - I don't know about a '68 but there are probably two sets of holes in levers that the linkage connect to. The three (can't remember if the reverse lever has two holes or not) that are on the side of the transmission. If you set it up your linkage to the other holes it make the shifter throw shorter......for quicker shifts.
On the bottom of the shifter handle there is a flat portion that lines up and passes though/across each of the open square portions in the linkage lever plates; this is also the area where the locating gauge would align the plates. Note about the shifter handle, the shift pattern is opposite at the bottom below the pivot point, as you put the shifter in first gear, forward left position, the bottom of the shifter is moved to the opposite right rear position. So the leaver plates are as follows from left to right: one plate for 3 & 4 on left, the center one for 1 & 2 and right side one for reverse. With the engine off pull up on the reverse lock out leaver and run through the gears to let them set in to their natural gear position. Then set the shifter in the neutral position and pull up on the reverse lock out leaver again then you should be able to move the shifter handle from side to side and feel as the bottom of the shifter handle passes through each of the three plates that they should not touch or bump the edges of the square pass through sections in the plates (don’t expect the plates to be perfectly lined up just feel that it passes though without bumping the edges of the plates. If you are bumping a plate you will need to adjust the transmission linkage nut just a thread turn or a few turns at a time until if feels clear. If you are bumping a plate on the forward front side (as if pulling the handle) you will need to extend the linkage rod, if you are pumping at the rear (as if pushing the handle) you will need to shorten the rod length, you should not have to pull or push the handle. It should be perfect when you are able to move the handle side to side with out bumping the plates. On another note if you are hitting the console at the front or back equally adjust the three transmission linkage rods (same number of thread turns) to center the shifter throw, if you are hitting in the forward 1, 3 or R shorten the rods or extend for 2 and 4th gears in equal thread length turns. Before you change any linkage count the number of turns to unthread the linkage bar so if you are unsuccessful you can return everything to the original starting point without father miss adjustment.
Attachment 48200813
