66 body back on frame problem/ question
Old Sep 5, 2017 | 10:29 AM
68bigblock's Avatar
68bigblock
Default 66 body back on frame problem/ question
When I put the body back on the frame of my 66 Convertible and tighten down on the frame bolts to factory specs---- the doors will not open? When the bolts a losly snug but not tighten the lines in the door are perfect and open and close perfectly. But when I tighten to specs, the door binds and will not open. What am I doing wrong? All the body shims were numbered and replace back to original at each location.
Thanks,
Old Sep 5, 2017 | 11:52 AM
Alan 71's Avatar
Alan 71
Hi 68,
I think this question about 'sequence' often comes up.
Even when the shim count is known, I'm not sure that it's wise to do final alignment of the doors and hood until the body is back on the frame.
You need to have the body FIRMLY in place on the frame and THEN begin aligning the doors and hood to set the gaps and transitions.
Regards,
Alan
Old Sep 5, 2017 | 02:05 PM
68bigblock's Avatar
68bigblock
Originally Posted by Alan 71
Hi 68,
Regards,
Alan
All the shims where counted when body was removed. I have followed Noland Adams procedure step by step. The doors bind and will not open once body-to-frame bolts are tighten. I did not have this problem with my 56.
Old Sep 5, 2017 | 02:07 PM
lakerider57's Avatar
lakerider57
Hi 68,
Regards,
Alan
There is a great previous link where the body shimming was discussed:
https://www.corvetteforum.com/forums...-the-body.html
Richard
Old Sep 5, 2017 | 02:54 PM
68bigblock's Avatar
68bigblock
Richard
All that was mentioned by Alan 71 was done to the 66. Shims were counted and replaced with the exact count.
So, I'm stumped!
Old Sep 5, 2017 | 03:04 PM
69ttop502's Avatar
69ttop502
I would probably start by adding some shims and see if it starts to resolve itself.
Old Sep 5, 2017 | 04:08 PM
Alan 71's Avatar
Alan 71
Hi,
Remember the frame was 'measured' in a jig, and the shim count was determined, BEFORE the frame/chassis ever had the body put on it.
I'd think that if the frame is in relatively good condition, and there's not reason to think it's been 'tweaked', putting the 'known' number shims on each mount and then setting the body in place BEFORE beginning to align the hood/doors and setting the gaps is a good way to proceed.
Regards,
Alan
Here's the chassis getting 'wrapped', note the shims are on the body mounts, but NOT covered with plastic.
Here's the body being placed on the chassis. Note the single sheet of plastic covering everything INCLUDING the body mounts. Once the car the body work was completed and the car was painted and home again I worked at each mount location to remove the plastic that had been trapped at the mount.
Old Sep 5, 2017 | 05:29 PM
theandies's Avatar
theandies
If everything lines up and looks good with the bolts loose then you tighten up the bolts and stuff goes south what I would do is add shims until everything is good with all the bolts tight. I know you counted the shims etc. but any time you take something apart it will not go back together in the exact same way. It probably won't take much.
Think about digging a hole then filling it in. Why is there less dirt and an indentation in the ground where the hole was every time even though you used the same pile of dirt you took out of the hole to fill it?
Good luck!
Old Sep 5, 2017 | 05:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Are you positive of the shim count... because nothing should have changed.
One issue we have here is when we pull the body the shims are either rotten to the core or completely gone. This makes it almost impossible to find the correct alignment without doing a complete re-shim. We just did a frame swap on a 1971 and the issues that came with this were horrendous. All the shims were rotted away so we started with nothing and a different frame.
So.. while you may know the original shims per mount and when you tighten the bolts it goes out the window, it sounds to me as if you need to add one shim to the mount in front of the rear wheels.
Sometimes using the original shim count works.. sometimes it doesn't.
IMHO,
Willcox
To 66 body back on frame problem/ question
