Drivers side manifold question
Old Sep 10, 2017 | 01:28 PM
tommyp401's Avatar
tommyp401
Default Drivers side manifold question
So I discovered this morning that I think a bolt fell out. I have a loud "backfire" inside the engine bay. Leave the car run in the garage and pull the throttle under the hood and I see a lovely blue flame coming from the manifold. Turns out there is a threaded hole where a bolt should be that the flame is coming out. It is right dead on to hit the steering box so driving it will not happen now.
Attached is a picture of the threaded spot. Any ideas what goes there or what size bolt I need to put in to close that? Fire in the engine bay seems unsafe 😂
Old Sep 10, 2017 | 01:50 PM
Alan 71's Avatar
Alan 71
Hi t,
That hole is where one tube of the Air Injection Reactor 'tree' attached to the exhaust manifolds.
There should be 4 threaded openings like the one in your picture in each manifold.
The others are probably plugged and you can plug this one too.
Regards,
Alan
Old Sep 10, 2017 | 01:56 PM
tommyp401's Avatar
tommyp401
Default Plug
Originally Posted by Alan 71
Hi t,
Regards,
Alan
Alan,
That's what I was hoping to hear. Do you happen to know what size, threading of bolt I should use to do that?
Thank you!!
Old Sep 10, 2017 | 02:09 PM
Bikespace's Avatar
Bikespace
I'm impressed you were able to get those out. I was trying this morning with mine. They are frozen in place.
I believe those are the remnants of the A.I.R/Smog injection tubes:
https://www.corvettemods.com/C2-C3-C...QaAuqmEALw_wcB
The PO may have removed the tubes, and plugged the hole. I have a set of these ready to go in, if I can ever get the old ones out:
http://www.rickscamaros.com/camaro-e...1967-1981.html
You may be able to find a plug that fits at Home Depot. Try this thread for the size:
https://www.corvetteforum.com/forums...plug-size.html
Old Sep 10, 2017 | 04:46 PM
68notray's Avatar
68notray
Make sure to use socket head set screws from a well-equipped hardware store (Junk stores like Ace won't have them). Do NOT use 1/4" pipe plugs, the tpi (threads per inch) is wrong and the thread dia tapers. Yours prob came out because Bubba put pipe plugs in there.
Old Sep 10, 2017 | 06:18 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Those holes are NOT pipe thread........
To Drivers side manifold question
