Ammeter Doesn't Work.
Old Sep 11, 2017 | 06:26 PM
Maymyvetteliveforevr's Avatar
Default Ammeter Doesn't Work.
Car was stored for 27 years and have since don't a body off. When I finally started the engine I noticed the ammeter didn't work.
I'm not that great at electrical but I did the following.
Installed a new battery as it needed one anyway.
Turned high beams/lights on, fan on high, no change in gauge movement.
Tested voltage at alternator and found it charging at 14.1 volt. I know it's an amp, not a volt gauge.
Replaced existing ammeter with new and still doesn't work.
Any suggestions on troubleshooting.
Old Sep 11, 2017 | 07:04 PM
DUB's Avatar
DUB
You have to verify that the wires that a re going to the ammeter have power on them as they should.....use your wiring diagram and check that out. One wire will be a black wire and the other will be a black wire with a white stripe...if I am not mistaken.
I do not trust the new gauges due to where they are made......but in order for the gauge to work...battery power MUST be on both of the wires that go to the ammeter.
DUB
Old Sep 12, 2017 | 06:17 AM
Thanks for the reply Dub, I'll have to open the center dash and check for power.
I was hoping there was an easier way in that there was an inline fuse somewhere that I could check first before opening up the center dash.
Old Sep 12, 2017 | 10:18 AM
lionelhutz's Avatar
lionelhutz
The most likely problem is the fusible links on the wires. The ammeter wires both connect to the main red charging/power wires under the hood. I believe on a 75 the black/white wire connection is on the left fender connected just downstream from the alternator and the black wire is connected along the firewall. Both wires should have a fusible link at the end making the connection.
Old Sep 12, 2017 | 10:31 PM
7T1vette's Avatar
7T1vette
The two signal wires going to the ammeter pass thru the firewall connector. If you separate that connector and find the terminals for those ammeter wires, you can use a penlight battery to make quick contact to the ammeter and see if the needle moves or not. If it does not, there is most likely a problem with the ammeter, itself (unlikely to be the wiring on the interior side). If the needle moves, the meter itself is fine, but there is a problem getting the signal from the engine wiring harness. {Using this test method avoids opening up the gauge cluster area until it is known that the problem lies there.}
If that is the case, the fusible links in that circuit should be checked. [Remember that when a fusible-link fails, the wire will melt inside the insulation; the insulation may be darkened, but it will NOT melt and may appear intact.]
If the links check OK and the car functions fine electrically, there must be a faulty connection or wire in the current sensing wiring.
To Ammeter Doesn't Work.
