Power Steering System Torque Specs??
What are the torque specs for the tapered bolts on the power steering system cylinder (connects to drag link bar? with a castle nut) and control valve (connects to steering box pitman arm with a castle nut)...or how do you know it's seated? This is on a 69. I'll periodically check but I've basically got everything as tight as I could but I don't know how tight is right?
Thanks.
Thanks.
I tighten the nut to 35 ft/lbs then advance the nut until I can put the cotter key in. But to make it easier to remove in the future coat the tapered pin and hole with Never-Seez first.
