1982 corvette c3
Old Oct 2, 2017 | 09:16 PM
pauliep103's Avatar
pauliep103
If you need good info on these cars tag dub he has good knowledge with these cars he’s on the forum I’ll post any good news when it starts, car is driving me nuts
Old Oct 2, 2017 | 09:21 PM
Bigredwing's Avatar
Bigredwing
I'm with you brother, and you are right about Dub. Add Wilcox to the list of experts too along with many others. The C3 Forum is a good thing to have in your tool box.
Old Oct 2, 2017 | 09:52 PM
pauliep103's Avatar
pauliep103
Yes sir this is my first week an I like it
Old Oct 3, 2017 | 06:37 PM
DUB's Avatar
DUB
Originally Posted by Bigredwing
I also get 8.5V at the tank connector for pump power. I think that is normal with the key ON. I tried 12 V directly to the pump motor using a battery charger but nothing happened with that too. Car ran great two days ago when I put it on my lift. What next?
Honestly I think that it needs to be at battery voltage....and not 8.5 volts The fuel pump needs 12 volts.
Electric motors... such as a fuel pump motor REALLY need all the voltage they can get and if the voltage drops too much...the efficiency of the pump greatly reduces. IF the voltage is less than battery voltage at the connector that plugs into your sending unit...that is telling me that you have a dirty connector somewhere....and the fact that because you applied 12 volts from your battery charger to make the fuel pump run does not matter...that is telling me that the pump is bad...or has a dead spot on it and the minute you tap it ( much like a power window motor) it works again...or it is the connector on the fuel side of the sending unit is bad.
Also...not wanting to be a smart@ss...the light bulb on your coffee table lamp two days ago also worked.... but when you went to turn it on today... the filament burnt out in it. Sometimes things can burn out that fast on some components. And that is coming from a guy who deals with 'stuff' going bad right while the Corvette is in my shop is having something else repaired. It makes no sense...but it happens.
DUB
Old Oct 3, 2017 | 06:42 PM
DUB's Avatar
DUB
'pauilep103'
IF your problem still persists....let me know if you want more help...if looking at otehr threadas and teh iunternet give ioyu nothing.
I looked at the 1982 shop manual today and as like has been previously mentioned..there is a way to get the electric fuel pump to run and by-pass the factory circuits if needed.
You are aware that there is a FUEL PUMP fuse a the very top of your fuse panel. There are 2 fuses at the very top and the top right one is your fuel pump fuse and it is 10 amp.
DUB
Old Oct 3, 2017 | 06:50 PM
L-46man's Avatar
L-46man
Guys...I'm an Engineer...I need you guys (those who are having problems) to seriously look at the GROUND CIRCUITS to (say) the fuel pump and relays et al.
EVERYBODY gets so concerned about how many volts on the FEED LINE. Okay, rightly so...like DUB says " you really should have about 12V going to the FP and or Relays or both."
HOWEVER...you are checking with a meter...EVEN if it says 12V DOES NOT MEAN THAT NEGATIVE! 12V is routing back to chassis ground nor the battery. {Its routing back through your meter}
SO...if you are checking ANY system on a Vette, who's body is NOT the ground, the chassis is...YOU MUST run a jumper wire from the NEGATIVE part of the circuit to KNOWN GOOD chassis ground or better yet, the neg term on the battery.
If it works THEN....BINGO....bad ground circuit.
Remember you can push 12Volts and .00001 amps and the meter will still read 12V! Volts is the size of the 'hose' amps is the flow rate through the hose.
Good luck Sirs! UnkaHal
Old Oct 3, 2017 | 07:30 PM
pauliep103's Avatar
pauliep103
Default Corvette
I haven’t had the chance to deal with this car I got stuck with a double and nothing got done I’ll keep you updated tomorrow sorry guys this car will be running by the weekend I’m off tomorrow and I’ll be on it
Old Oct 3, 2017 | 08:01 PM
pauliep103's Avatar
pauliep103
Default Checked out where cigarette lighter
I removed the cigarette lighter and there was the plug on the right side I’m getting power only their others are dead
[img]webkit-fake-url://d91184f6-119b-4f31-a177-92ce8cdcd6d4/imagejpeg[/img]
Old Oct 4, 2017 | 09:01 AM
Bigredwing's Avatar
Bigredwing
DUB
If THAT doesn't describe a 35 year old car on the cusp of modern technology nothing does. Now to get to work on it.
Old Oct 4, 2017 | 01:06 PM
Bigredwing's Avatar
Bigredwing
Here's to a 10 amp Fuel Pump fuse on the main fuse panel that lost all its anti-blow properties and caused my fuel pump to quit. Hopefully it is a fluke that occurred while troubleshooting my fuel sender/fuel gauge issue. I think I'll work on something else for a while.
Old Oct 4, 2017 | 06:56 PM
DUB's Avatar
DUB
EXACTLY!!! I appreciate you bringing that up.
I encounter problems in electrical issues from time to time where....a wire will have 12 volts.....it will ohm out perfectly so I know it is a continuous wire....BUT...18 out of the 19 strands of copper that make up that gauge of wire are broken...and when the component needs to power up and work...it commands so many amps that that single strand of copper can not allow the part to get the AMPS it needs.
YUP!.
DUB
Old Oct 4, 2017 | 08:29 PM
pauliep103's Avatar
pauliep103
Default Checked cigarette lighter
Old Oct 5, 2017 | 11:32 AM
  #33
L-46man's Avatar
L-46man
Paulie...you can post a pick directly to the site....Corvette Forum is very civilized! LOL. Its the two left most pins on the ADL.
Old Oct 5, 2017 | 06:50 PM
  #34
DUB's Avatar
DUB
You did not need to remove your cigarette lighter if you were looking for the ALDL connector...all you had to do was poll out your ashtray.
DUB
Old Oct 5, 2017 | 08:16 PM
  #35
pauliep103's Avatar
pauliep103
I did dub I pulled out astray and there was a plug their
i placed a test light and received power out of the right side
Old Oct 5, 2017 | 08:20 PM
  #36
pauliep103's Avatar
pauliep103
Default Here’s a pic
[img]webkit-fake-url://0eb5e455-fad3-4412-abe7-69a13ca3e327/imagejpeg[/img]
Old Oct 5, 2017 | 08:23 PM
  #37
pauliep103's Avatar
pauliep103
Default Plug under astray! Sorry I’m just starting to know the site an how to use it 😂
right lower pin lights up I guess that’s power correct how do I jump it to run the pump
To 1982 corvette c3
Old Oct 6, 2017 | 06:46 PM
  #38
DUB's Avatar
DUB
Have you obtained a wiring diagram yet???
To post a photo..the way I do it is to save it in my computer....then...the yellow box that looks like a mountain inside of it right above where we type out our posts...in the task bar....'click' on it and a screen will come up....you have a choice of getting the photo from a URL or 'browse your device' and find it in your computer.
DUB
Old Oct 7, 2017 | 12:42 PM
  #39
pauliep103's Avatar
pauliep103
No not yet I’m working on the car right now I’m starting to think the fuel sender wire came off inside the tank
Old Oct 9, 2017 | 04:10 PM
  #40
pauliep103's Avatar
pauliep103
Was dub finally got the car running !!!�� I did a temp fix ran a wire straight power to
The pump with a switch definetly have a
Broken wire somewhere I need a diagram for this car anyone knows where I can Download one from or can one be emailed to me paort2@aol.com thanks guys for patience and help
