Your auto parts store will stock the correct valve with the "T" fitting. My '82 uses one with a "T" fitting so you could look at one of those and see if that's what you need.
Perfect - no mas gas smell stinking up the garage!
Hi Len,
When you purchase the new 'T', or 'T' and pcv valve, make sure the nipple on the 'T' for the hose that runs up from the canister is the correct size.
Regards,
Alan
In 71 for instance, the hose from the canister to the T is smaller than the hose from the pcv to the carb.
