So I recently had my suspension, brakes, and steering redone, and all re-aligned with fresh tires. The car track really straight under cruise, as well as hard acceleration; however, with hard braking it pull STRONGLY to the right.
I'm thinking this may just be a simple bleeding issue or is there something else I should be checking?
Bleeding brakes is the right place to start, while you are doing that get under the car and challenge all steering connections and suspension attachment points.
When you pull to one side or the other it means the side you are NOT pulling to is the problem.
Since your pulling to the right I'd start by checking your left side calipers etc. Possibly a small leak that's coated the pads, air in the lines as silver74vette said or some other problem.
Also check The front left calliper doesn't have a leak. My front right continued to leak after new seals were fitted, turns out it had a poorly fitted stainless sleeve and was leaking around the outside of it.
Your left side caliper has a leak which is allowing brake fluid to get on the pads; reducing their friction. If the inside side of your left tire is darker than your right tire that's a sign of leaking brake fluid.
Thanks everyone - i figured as much, but have never really tried to bleed any brakes, ever... one of those things I've kind of been reluctant to try, you know, wanting to be able to stop and all - haha. How big of a PITA is this, and do I need to get anything to do this?
1/4 inch tubing and a bottle, small wrench (small six point is best) a capable helper and some patience. I always get a good feel for the pedal (after the vacuum is released from the booster) and compare it to see how the system feels.
Bleeding brakes is easy if you have the right person at each end. lolol First the the car up in the air safely just enough to get tires off. Have a good lite, and clear 1/4 hose is best, that way you can see the trapped air coming out if there is any? CHECK FLUID LEVEL IN MASTER CYLINDER FIRST BEFORE YOU DO ANYTHING. MAKE SURE ITS TO THE CORRECT LEVEL THEN REPLACE COVER FOLLOW INSTRUCTIONS BELOW.
Use box end of the wrench, put it on the bleeder screw connect hose to bleeder screw,have person in the car pump the brake pedal 3 times and hold it. Crack bleeder screw open brake pedal will go to the floor and fluid will come out.
Have person hold pedal to the floor while you snug bleeder screw, once screw is tight, person can pump up brakes again open bleeder screw let pedal go to floor hold it there tighten screw repeat. Do this 3 times then top up master cylinder with brake fluid. Do this till you see no bubbles coming out. then move to next wheel.
Thanks in advance...
Howdy, I have the same issue just had new caliper installed right side new shocks, pulls to right when braking, have it in the shop hope I will have it back tomorrow will keep you in formed
Check the age of the rubber brake lines. Old and corroded lines can act as a check valve and create an imbalance in the system. The lines may look fine from the outside, but could be clogged on the inside. Jerry
you had your suspension, brakes, etc done? as opposed to you did it yourself. the guy who did the work is the guy to see. you paid someone else becuz you wanted a better job than you felt confident of doing yourself? did he replace all 4 flexible brake lines? don't check em, replace em. and that will give him a paying job instead of trying to get him to redo his work. mechanics tend to be a little more thorough when getting paid. if it is warranty work, crank it out and give the customer an excuse...
Air bubbles compress and generate little braking force. So it is possible if you have air bubbles in the left front caliper. The bubbles tend to corrode the calipers too and make them leak in the first place.
He hasn't been on the forum in three years, I'm sure his problem must have been fixed by now
