Have you ordered the new circuit board yet? unless it's mechanically damaged I would think a thorough cleaning would restore it to good working condition. And what does the other side of those steel things look like? Are they crimped on the opposite side? If they're supposed to be making contact with the copper bars they may not be because of oxidation or ? If you could remove them you could try giving them a coating of solder and then re-crimp them.
Well I actually ordered this pcb in error. I intentended to get the other board for the gauges. When I discovered my error the part had already shipped. SO I decided, while everything was apart, I would just changed it also.
Went against my own rule: if it ain't broke, don't fix it. Probably do as suggested. Clean it well and leave it in.
Anybody need an extra speedo/tach pcb?
I did replace my PCB, but it was years ago. But, I don't remember it being all that difficult to release those connectors. Look at Willcox's instructions for replacing the tach board to remove the tachometer so you can gain access to those release clips.
Give it a good look over first. Mine looked great (mostly) when I replace it. There was just one track in the corner that had lifted, it was almost about to create a short. Even in my photos of it it's hard to see the problem.
