Is my MAP sensor going bad ?
Old Oct 6, 2017 | 06:06 PM
Gordonm's Avatar
Gordonm
Default Is my MAP sensor going bad ?
Manifold vacuum is at 8 to 9 inches. I have an EZ efi 2.0 and looking at the master screen while idling it is showing around 68-70. Jumping a little but so does the 8-9 inches I am getting on my vacuum gauge. Now I am running a pretty healthy cam so the 8-9 is about right but why is the computer showing 68-70. That converted is about 20 inches. The car all of a sudden started cruising very poorly. Low speed 1500 to 2300 rpm is not good at all. WOT the car runs good but could probably run better.
Old Oct 6, 2017 | 08:22 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
It's been a long frustrating day, so I welcome any corrections if my thinking is foggy this evening.
The MAP reading looks correct to me. A vacuum reading of 8-9" Hg means that the manifold is only about 1/3-1/4 depleted of normal air pressure (Full depletion would be 30" Hg). IOW, the manifold at 8-9" Hg is 2/3 to 3/4 full of normal air pressure (14.7 psia). Full manifold air pressure (14.7 psia) as read by a MAP sensor is IIRC 105 kiloPascals. Take 2/3 to 3/4 of 105 kPa and you get about 68-70 kPa.
Again, I invite corrections if I'm thinking wrong this evening.
Last edited by 69427; Oct 6, 2017 at 08:23 PM. Reason: Grammar correction. Long day.
Old Oct 6, 2017 | 09:36 PM
zwede's Avatar
zwede
^^^^ Yes, that is correct.
Assuming sea level, 0" of vacuum is a map reading of a little over 100. Perfect vacuum will be a map reading of 0.
The higher the altitude the lower the 0" vacuum reading will be.
Old Oct 6, 2017 | 10:10 PM
Gordonm's Avatar
Gordonm
I own a chainsaw and a couple of hand guns so I will take this into consideration and look elsewhere for a problem. Thanks for the info.
Old Oct 7, 2017 | 07:02 AM
Gordonm's Avatar
Gordonm
I was having one of those days yesterday where my brain was not thinking. I was bassackwards yesterday. Thinking 0 kpa. Was atmospheric pressure on the map. Went out this morning and just turned the ignition on and the sensor reads 105kpa. So it seems to be working correctly. I'll have to look elsewhere for the rough running.
Old Oct 7, 2017 | 01:46 PM
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
Fuel pump, fuel filter, air filter, just some things to check.
To Is my MAP sensor going bad ?
