where is gearing stamped on 69 corvette rear end?
1969 corvette rear end is not the original and i need to know how to tell what ratio it is? I have trans out to change the drive gear that has come loose. So need to replace with correct one! Thanks Matt.
Emerging Vendor
There is a code stamped into the bottom of the diff case adjacent to the cover. It will be be dates and a two digit letter code for 69, 3 letter code for 1970 and up.
Matt6969 (10-07-2017)
Received 2,878 Likes
Hi Matt,
Welcome!
First post!!
Here's an example of the location and stamps that Greg described.
Regards,
Alan
This is a 71 differential:
LR …3.36:1 Positraction
W…. Axle Plant... Warner Motive
12…12th day of 1971
E….Positraction Source..Eaton
1… shift the unit was assembled on
Welcome!
First post!!
Regards,
Alan
12…12th day of 1971
