Power steering whine
Old Oct 13, 2017 | 01:38 PM
croaker's Avatar
croaker
Default Power steering whine
My pump is whining like its low on fluid. It's not low and not that old. What else should I check?
Old Oct 13, 2017 | 02:26 PM
MelWff's Avatar
MelWff
a brand new pump can whine if it is defective, why do you think it is anything other than a failing pump?
Old Oct 13, 2017 | 02:37 PM
71VetteLover's Avatar
71VetteLover
Any vane pump will whine if a anti-foaming oil isn't used. When air gets mixed into the oil the pump vanes will cavitate which makes noise so you must use an oil designated for power steering pump use. I have always used ordinary ATF because I always have it in my stock.
Old Oct 13, 2017 | 02:54 PM
Haggisbash's Avatar
Haggisbash
I had a noise at one time that sounded like the PS pump but turned out to be the alternator.
Old Oct 13, 2017 | 06:35 PM
sunflower 1972's Avatar
sunflower 1972
Usually a power steering pump will whine when under a load (turning the steering wheel) with the engine running. An alternator whine will usually get louder as the engine rpm's increase. You can use the old rubber hose stethoscope trick to isolate the noise.
Old Oct 14, 2017 | 01:58 AM
croaker's Avatar
croaker
I meant to say fluid is not that old. Other then whining what can I check. It is the pump making the racket. Typical pump in a bind sound.
To Power steering whine
