1971 lt1
Old Oct 14, 2017 | 09:47 AM
thelal1's Avatar
thelal1
Default 1971 lt1
Can you run solid lifters on a hydraulic cam
Old Oct 14, 2017 | 09:50 AM
Dynra Rockets's Avatar
Dynra Rockets
no.
Old Oct 14, 2017 | 10:01 AM
fishslayer143's Avatar
fishslayer143
ditto.... the lobe ramp is designed differently .. solid lifters on hyd cam will beat itself to death ... why would you do this? you want more rpm? get anti-pump-up lifters or just join the 21ST century and go ROLLER!!
Old Oct 14, 2017 | 11:42 AM
gkull's Avatar
gkull
You can use solid rollers on a H roller cam. Not much can be gained from using solid flat lifters
H flat cams can do in excess of 7000 rpm if you pay close attention to valve weight and springs
Changing rocker ratio has some minor benefits
Old Oct 14, 2017 | 12:04 PM
71VetteLover's Avatar
71VetteLover
You could for a little while but then the shock load would probably cause push rods to bend or valve heads to break off.
To 1971 lt1
