Tach board
Old Oct 14, 2017 | 10:47 AM
michaelroy's Avatar
michaelroy
Default Tach board
Just removed while swapping in new dash. Do you think the dark color at upper right of boards indicates any problems?
Old Oct 14, 2017 | 11:06 AM
henrikse's Avatar
henrikse
Hard to see in shadow but definitely overheating problem. Say many boards like this during career. Question is it old damage and been repaired? You should be able to tell if the solder looks different in area (new vs old) If you can plug it in and see if it is heating up here.? If it is there is either a resistor or power transistor that is causing. If it is cool and old damage you could leave. If it is hot I would look for a new one as it can become brittle.
