Rear end ratio
Old Oct 18, 2017 | 02:05 PM
jhopper408's Avatar
jhopper408
Default Rear end ratio
I have 1977 L48. I was just wondering if there is a way to tell if speedometer to tachometer will tell you the rear end ratio. At 70 mph. I'm exactly at 3000 thousand rpms?
Old Oct 18, 2017 | 02:12 PM
jhopper408's Avatar
jhopper408
Oh. By the way it's a automatic.
Old Oct 18, 2017 | 02:13 PM
jhopper408's Avatar
jhopper408
The stats I found say that it's a 3:08.
Old Oct 18, 2017 | 02:15 PM
silver74vette's Avatar
silver74vette
what is your rear tire size? If you are running about a 235 70 R 15 you have about a 3:42 ratio.
Old Oct 18, 2017 | 02:18 PM
silver74vette
If you are a 235 60 R 15 I would say you were a 3.08. My calculations show that a 3.08 would be about 72 MPH with 6% slip.
Old Oct 18, 2017 | 02:19 PM
jb78L-82's Avatar
jb78L-82
Then standard ratio for an L-48 auto from the factory was 3.08 and optional 3.55....
Old Oct 18, 2017 | 02:38 PM
jhopper408's Avatar
jhopper408
There P225/ 70 -15s
Old Oct 18, 2017 | 03:07 PM
Alan 71's Avatar
Alan 71
Hi jh,
The differential case was stamped with a code for the ratio with which the differential was originally assembled.
It's stamped along with some date and source information on the bottom of the housing rear flange.
Might take a peek?
Regards,
Alan
I believe these are for 77 cars:
OA 3.08:1
OD 3.36:1
LR 3.36:1
OB 3.55:1
OC 3.70:1
An example from a 71.
Old Oct 18, 2017 | 03:29 PM
silver74vette
Based on the info from Alan 71 and your tire size. My calculator shows your car with a 3.36 ratio. This is based on 4% slip (120 rpm loss) which is very close to what a stock converter should be in a TH400. The speed I show is 69.9 MPH @ 3000 RPM.
Old Oct 18, 2017 | 03:30 PM
jhopper408's Avatar
jhopper408
Thanks guys. I guess when I have it up in the air, I'll check it out!
Old Oct 18, 2017 | 05:00 PM
jb78L-82's Avatar
jb78L-82
Don't assume that the factory tach is correct with its readings. My 78 OEM tach reads 300-400 RPM higher than the actual RPM's...check out the thread about tach accuracy. 78 L-48 autos came only with 3.08 and 3.55 gears. Check out the specifics for 77's at :
GM heritage center.com
My guess is that 77 L-48 autos used the exact same gears.....
Old Oct 18, 2017 | 05:09 PM
HeadsU.P.'s Avatar
HeadsU.P.
The code numbers only show what it came with from the factory. Who knows what's in there now after 40 yrs. Do the count tire / driveshaft "thing".
Old Oct 18, 2017 | 07:41 PM
OldCarBum's Avatar
OldCarBum
My 73, TH-400 with 245-60-15 tires, with 3.36 gears runs at 2964 RPM @ 70 MPH.
If you want a more accurate way to check the rear end ratio that takes the tach error and tire size out of the equation, lift "BOTH" rear tires off the ground, mark the inside of the outer rim lip with a marking pin, and mark a single line on the bottom of the drive shaft, rotate the wheel one full revolution of "forward movement" and count the number of turns the driveshaft rotates. 3.36 turns and you have a 3.36 gear ratio, 3.55 turns and the rear ratio is 3.55, 3.08 turns 3.08 ratio, 3.7 turns 3.70 ratio, and so on.
It's the most accurate way without pulling the diff cover and inspecting the ring and pinion gears.
Old Oct 19, 2017 | 07:10 AM
jb78L-82's Avatar
jb78L-82
My 73, TH-400 with 245-60-15 tires, with 3.36 gears runs at 2974 RPM @ 70 MPH.
I think the only way to really accurately determine the rear end gears is this method ^^^^^ unless you have owned the car since it was new....
Old Oct 19, 2017 | 08:42 AM
HeadsU.P.'s Avatar
HeadsU.P.
The problem is when you are laying on your back, turning the tire and trying to count the driveshaft rotations, its pretty much impossible to determine the distance of for example, 3.36 and compare to 3.55 on the shaft itself. What circumference does that come out to? A fraction of an inch. Some axles have enough play in them to fool you on the counting incorrectly. Even when marking the driveshaft with a piece of masking tape and a felt pen it can be difficult to measure accurately but will give you a rough idea.
Old Oct 19, 2017 | 08:55 AM
69autoXr's Avatar
69autoXr
I calculate that the 3.55 would turn approx 1.5" further than a 3.36, assuming a 2.5" drive shaft diameter (ballpark, I don't know for sure that it's 2.5"). It should be pretty obvious if you've gone 3 + ~.3 turns vs. 3 + ~.5 turns.
Old Oct 19, 2017 | 09:24 AM
HeadsU.P.'s Avatar
HeadsU.P.
Could be. I slept through algebra class. Inch and a half seems like a lot though. I was thinking more on the lines of 1/2" difference?
To Rear end ratio
Old Oct 19, 2017 | 11:26 AM
OldCarBum's Avatar
OldCarBum
It is close but pretty obvious. I usually check it two to three times just to make sure I'm right.
Old Oct 19, 2017 | 01:27 PM
CA_WxMan's Avatar
CA_WxMan
I plugged your tire size into a gear ratio calculator that I made in excel, but it doesn't factor in converter slippage or tire wear.
With a 225/70-R15, it says that 3000 rpm with 3.36 would put you at 73 mph and 3.55 gears would have you at 69 mph.
I've attached a couple of screen captures.
I don't think I can upload an excel file, so if anyone wants a copy of the calculator, just send me a PM.
Old Oct 19, 2017 | 02:29 PM
silver74vette
Way better looking than mine but we are both right in the same spot.
